Exporting to Other Tools
If you're working across multiple design tools, then you may wish to export or copy across objects, groups or entire Frames into another system.
You can drag SVG files exported from Figma directly into both Sketch and Illustrator.
For Adobe XD and Affinity Design users, use the Copy as SVG option in Figma to copy the layer or group, then Paste the SVG directly in the other tool.
You can also export your Files from Figma to other tools in your workflow via our purpose-built integrations:
Tip! Want to export or download an entire file? Head to File > Save as .fig file from the menu:
