Leave a Team
Who can use this feature?
✅Users in Starter, Student, Professional or Figma Organization Plans
✅Any Team Member can choose to Leave a Team
If you no longer need to be a part of a Team, you can leave it. When you leave a Team we will:
  • Revoke your access to that Team, including any Files and Project.
  • Transfer ownership of any Projects or Files you created to the Team Owner.
  • If you're the last member of the Team, we will delete the Team. This will delete any Files and Projects. This action is permanent and cannot be undone.
Are you the Team Owner and planning on leaving your company? We recommend transferring any Teams, Files and Projects you own, and updating the Team's billing.
Leave a Team
  1. Open the Team page in the File Browser.
  2. Click on the Team name in the Toolbar.
  3. Select Leave Team from the options.
  4. We will prompt you to confirm. A Team Member will be able to invite you back to the Team, if needed. Click Leave Team to confirm.
  5. We will remove you from the Team.
