Frame Tool
Under the drop down menu for the Region Tools, you'll find the Frame Tool. To add a Frame to your Canvas:
  1. Select "F" (or "A" if you're more familiar with the term Artboard)
  2. Drag out a Frame onto your Canvas
Manually entering the dimensions of your Frame in the Inspector on the right side...
Or select the drop down menu next to Frame, and select from a number of predefined sizes.
