Adjust Permissions on a File
Who can use this feature?
✅Users in Professional or Figma Organization Plans
Team Owners, Admins or File Owners can adjust a File's Permissions
You can create Files within Projects in a Team. Or, work on Personal Files in your Drafts.
Generally, any Files created within a Team will be accessible to all Team Members.
Team Members will be able to interact with any Files based on their  permissions. Learn more in our Manage Permissions in a Team article.
You can adjust a collaborator's access to a File in your Drafts.
In a Professional Team, you can adjust a collaborator's Permissions on each File.
This allows you to:
  • Upgrade a Viewer to an Editor
  • Downgrade an Editor to a Viewer
Note: When you upgrade someone to an Editor on a File, we will also include them as an Editor in your billing. We won't make any changes to their Team Permissions.
Adjust File Permissions
You can adjust a Team Member's Permission on a File via the File Sharing modal. This allows you to:
You can access this from a few places:
Project Page
  1. Open the Project page in the File Browser.
  2. Right-click on the File to open the File menu.
  3. Select Share from the options:
Working on a private Project? Learn more about Advanced Project Permissions.
Editor
  1. Open the File in the Editor.
  2. In the toolbar, click the Share button:
File Sharing
  1. Open the File Sharing modal (see above)
  2. Click the arrow next to the member's current access.
    • Select Can View to make them a Viewer
    • Select Can Edit to make them an Editor
    • Tip! In Student, Professional and Organization Teams, you can Prevent Viewers from Copying or Sharing Files.
  3. Click the X to close the Sharing modal and return to the File.
