Join an Organization
Who can use this feature?
✅Users on the Figma Organization plan
Already joined the Organization and want to log in? Learn more in our Log in to Figma article.
To participate in the Organization, you will need a Figma account. You can join an Organization via any of the following methods:
Regardless of the method, you will be required to log in to Figma using your company email.
Accept an Invitation
An Organization member can invite you to a Team in an Organization as a Member or a Guest. You can accept the invitation to access the Organization.
Required: Be invited to a Team in the Organization.
💻 Supported: Figma Desktop app, Figma Web app, Figma Mirror on iOS and Android.
  1. Open your email and find the invitation.
  2. Click the Accept Invite button.
  3. Enter your company Email address and choose a Password.
  4. Click the Create account button.
Log in with your Company Email
We will add you to the existing Organization when you sign up with your company email.
Required: Domain Capture enabled for the Organization.
  1. Head to the Figma website and click the Sign up button in the top-right corner.
  2. Enter your company Email in the field provided.
    Note: This will need to match the domain(s) registered to the Organization.
  3. Enter a unique Password.
  4. Click Sign in to complete the process and access your account.
Join an Organization using SAML SSO
If your Organization has SAML SSO enabled, you can sign in using your company email and password.
Required: SAML SSO must be enabled for the Organization.
💻 Supported: Figma Desktop app, Figma Web app, Figma Mirror on iOS.
🚫 Not supported: SSO is not supported via the Figma Mirror app on Android.
  2. On the Sign up page, click the Sign up with SAML SSO link in the bottom right-corner.
  3. Enter your Email in the field provided and click **Sign in.**This will perform a check to ensure the domain is registered to an Organization.
  4. If the domain is registered, you will then be prompted to enter your Password. This is the same password you would use to access your company account.
  5. Click Sign in to complete the process and access the account.
Note: If the domain isn't registered to an Organization, you will receive an error message. "This domain is not configured to use SAML SSO. Please sign in with Google or a password"
SAML SSO needs to be set up by your account administrator first, so if you're not sure then we recommend checking in with your Account Administrator to confirm.
Log in via Google SSO
If you have a Google account, you can sign up for a Figma account via Google's Single Sign-On (SSO) process.
Required: Company domain is managed by Google SSO.
  1. Head to Figma.com and click Sign up in the top right corner: https://www.figma.com/signup
  2. Click the Sign up with Google button.
  3. If you're already logged in to Google, you'll simply be prompted to confirm your details.
  4. Otherwise, enter your Google Email address or Phone number and click Next.
  5. Enter your password and click Next to complete the process.
