Update your Name or Avatar
Who can use this feature?
✅Anyone with a Figma Account
✅Users on any Figma Plan
❌Organization Members with SAML SSO enabled
Your Name and Avatar make up your identity in Figma.
  • We use your Name and Avatar to identify you in any Teams, Projects or Organizations you are a part of.
  • When you view a File or Prototype, we add your Avatar to the toolbar. This allows everyone to see who is currently accessing the File.
  • We include your Name on your Multiplayer Cursor. This allows others to see your actions in the Canvas.
You can update both your Name and your Avatar in your Account Settings.
I want to:
Change your Name
Log in to Figma via SAML SSO? Your Organization's SAML SSO provider will control your account details. You will need to contact your Organization Admin to update your display name there.
From your Account Settings:
  1. Hover over your name in the header.
  2. Click on the Edit Pencil once it appears.
  3. Type in the new name in the field.
  4. To apply your changes, press the [Enter] key. Or, click anywhere outside the field.
Update your Avatar
If you haven't added an Avatar, we will identify you by a colored circle with your initials.
You can upload an Avatar from your computer, so any collaborators know who you are.
  1. Hover over the current avatar.
  2. Click the Edit Pencil to make a change.
  3. A window will pop up that allows you to select an Avatar from your computer. Select the photo from your computer and click Open to upload.
  4. Use the slider to select the desired zoom/crop level:
  5. Click Save to apply.
