Measure Distances between Objects
You can measure distances, in pixels, between objects on your canvas with the steps below:
- Select an object
- Hold the alt/option key while hovering your cursor over other objects
- Figma will display redline distances to nearby edges.
Also, if you have Guides on your frames you can now measure distances between objects in the frame and those guides.
