Manage plugins in an organization
Before you start
Who can use this feature
Supported on the Figma Organization plan
Only organization admins can approve, install, and uninstall plugins for the organization.
Plugins are third-party scripts or applications that extend the functionality of an application. Figma plugins only run in the Editor and let you to perform tasks within files.
In a Figma Organization, you have access to extra features that control how members use and share plugins.
- Share both private and public plugins within your organization.
- Approve plugins that members can use within the organization space.
- Install or uninstall plugins for everyone in the organization.
Private and public plugins
Organizations will often have their own systems and tools they have developed. They can include private information or data that members can't share outside the organization.
Figma supports private plugins in an organization. This allows other members of the organization to use these plugins, without having to share them with the rest of the Figma Community.
- Any member of an organization can make and share a private plugin.
- Only Team admins can share publish plugins to a team's public profile.
- Only organization admins can share publish plugins to a organization's public profile.
Note: An organization admin can change a plugin's access, at any time. This allows you to update a public plugin so that it's only shared with the organization, or share a popular private plugin with the wider Figma Community.
To update plugin access you can publish an update to the plugin. Update the Publish to setting to change who can access the plugin. If you're changing a plugin from private to public, it will need to go through our review process.
View private plugins
To find and install plugins that are private to your organization:
- Open Figma in the File browser.
- Click on the organization name in the sidebar.
- Select the Plugins header at the top of the page.
- Browse through any plugins that are private to your organization.
- Click the ↓ Install button to add the plugin to your account.
Approve plugins
Enable the approve list to control which plugins members can use within the organization space.
When enabled, organization members can only install and run public plugins that are on the approve list. This includes any plugins members installed before turning on the approve list.
They can still view public plugins that aren't on this list, but not run them. Organization members can also use any plugins that have been shared privately within the organization.
Enable approved plugins list
- Open Figma in the file browser.
- Select Admin Settings in the sidebar and click the Settings tab.
- In the Other section, toggle on Approved plugins.
Note: Figma reviews every plugin that members publish to the Figma Community for overall quality.
Due to the nature of the plugin development process, Figma isn't able to perform extensive reviews of a plugin's privacy and security.
Figma does not review plugins that are shared privately within the organization. Learn more about our Plugin Review Guidelines.
Add approved plugins
Adding a plugin to the approve list allows organization members to install and run these plugins in the organization space.
Note: There isn't currently a way for members to request an approved plugin in Figma. Members will need to contact an organization admin directly to add a plugin to the approve list.
- Go to the plugin listing that you want to approve.
- Click Copy link in the Share section to add the plugin URL to your clipboard.
- Select Admin settings in the sidebar.
- Select Resources at the top of the page, then select Approved plugins.
- Click to add a plugin to the approve list.
- Paste the plugin link in the field provided and click Add to confirm.
- Figma will add the plugin to the list of approved plugins.
Remove approved plugins
Removing plugins from the approve list will prevent members from using the plugin in an organization files. That applies to any files within the organization space.
Members can still use public plugins in their personal space.
- Click the icon next to the plugin and select Remove plugin.
- Figma will remove the plugin from the approve list.
Spotted a suspicious or inappropriate plugin? Report the plugin to the Figma team.
- Open the plugin page and scroll to the bottom.
- Click the Flag as inappropriate link at the bottom of the page.
- Use the field provided to add any relevant details then click Send message.
Install plugins for the entire organization
If you are an organization admin, you can install plugins for the entire organization. When you install a plugin for everyone in the organization, Figma will:
- Install the plugin for every member of the organization. It's not possible to install plugins for a specific team or group of members.
- Make the plugin available in the editor.
- If you have the approve list enabled, Figma will also add the plugin to the approve list.
Install for everyone
- Find the plugin you'd like to install.
- Click the arrow next to the Install button.
- Select Install for everyone at organization.
- Figma will add the plugin to the Installed by <organization> section of the plugins page.
Uninstall for everyone
If you are an organization admin, you can also uninstall plugins for members. This will remove plugins for every member of the organization.
Uninstall plugins from any of the following places:
- Plugin page
- Plugin card or item in search results
- Organization plugins page
- Hover over the Installed button.
- Click the arrow next to Uninstall and select Installed for everyone at <organization>.
- Click Uninstall to confirm.
