Find and install plugins
Before you start
Who can use this feature
Anyone on any team or plan can access the plugins feature.
Anyone with can edit access to a file can run plugins.
People on the Organization plan may only be able to install approved plugins. Learn how to manage plugins in an organization →
Plugins are third-party scripts or applications that extend the functionality of Figma or FigJam. Use plugins to customize your experience or create more efficient workflows in Figma design or FigJam files.
Each plugin has a listing with information about the plugin, including instructions for use and a detailed version history.
Interested in making plugins for Figma and FigJam? Figma's plugin API supports both read and write functions, allowing you to view and edit existing layers as well as create new ones.
- Learn how to make plugins for the Figma Community
- Explore the Figma plugin API developer docs
- Connect with other plugin developers in the Figma Plugin Slack Community
Find plugins
Search and browse plugins built by creators from the community. There are a couple of ways to search and browse plugins.
In the file
Access plugins from the Figma Community directly from your Figma design and FigJam files.
Figma design
- Right-click the canvas.
- Select Browse plugins in Community. This will open Figma Community in a separate tab where you can search and browse plugins in the Figma Community ↓
FigJam
Use the toolbox in the FigJam toolbar to find plugins made for FigJam.
- Open the toolbox. There are several ways to do this:
- Click on the bottom toolbar, then click Plugins
- Right-click the board > Plugins > Browse plugins
- File menu > Plugins > Browse plugins
- Using quick actions > Browse plugins
- From the Plugins tab:
- Use the Recents section to find plugins you've installed that work in FigJam. These will be sorted based on your recently used plugins.
- Click See all for a category to explore Community plugins.
- Use the Search bar to find specific plugins by name or creator.
- Click on the plugin to view a description of the plugin.
Figma Community
Find plugins in the Figma Community through browsing or using the search bar. Guide to Figma Community →
Plugins in the Figma Community will note if the plugin was made for Figma design, FigJam, or both:
- Made for Figma design
- Made for FigJam
- Works everywhere
Part of an organization? Find plugins that are private to your organization in the organization. View and install private plugins →
Organization admins can only also install plugins for the entire organization. Install plugins for the organization →
Browse
Browse the Community in your browser, Figma desktop app, or mobile web:
Select Community in the left sidebar, or visit figma.com/community/plugins.
Select the Plugin pill at the top.
Click Figma design or FigJam categories to narrow down your options.
Search
Open the account switcher in the top-right corner and select Plugins, or visit figma.com/community/plugins.
Use the Community's Search bar for specific plugins by keyword or category, explore popular plugins, or find plugins from creators you follow.
Select Plugins to filter your results to Community files.
From the Figma community, click on the plugin name to open the plugin page and learn more about it. From the plugin page you can:
- Install the plugin on your account
- Click ♡ to like the plugin.
- Check if the plugin was made for Figma design, made for FigJam, or if it works everywhere.
- Select tag to explore other Community files and plugins that use the same tag.
- View updates, bug fixes and improvements in the plugin's Version history.
- Reach out to the plugin developer or get help using the Support contact (Figma is not able to provide support for specific plugins).
Install a Plugin
When you install a plugin, you will be able to run the plugin in files in your drafts, as well as within team files.
Figma links any plugins you install to your Figma account. If you've added profile connections, installing a plugin will install the plugin on your connected accounts.
Plugin listing
- Open the plugin's listing.
- Click the Install button in the top-right corner.
- Figma will add the plugin to your account and the plugin will show as Installed. Manage installed plugins →
Search results
Install a plugin from your search results, from within the Figma Community or via universal search.
- Find the plugin you want to install.
- Click ↓ Install on the plugin.
- Figma will add the plugin to your account.
In the file (FigJam only)
- Open the toolbox and click Plugins.
- Click Run next to the plugin to install it
Note: If you run an uninstalled plugin in a FigJam file, the plugin will automatically be installed.
