Manage your saved plugins
Before you start
Who can use this feature
Anyone on any team or plan can access the plugins feature.
People on the Organization plan may only be able to use approved plugins. Learn how to manage plugins in an organization →
View saved plugins
View and manage your saved plugins from within a file or the Plugins tab of your account settings.
You can only save plugins on Figma design. Figma links any plugins you’ve saved to your Figma account. If you’ve added profile connections, saved plugins will display across your connected accounts.
Want to manage plugins you have developed? Learn how to manage plugins as a developer →
View your saved plugins by doing one of the following:
From the file browser
- Click the account menu in the top-right corner and select Plugins.
- From the plugins management modal, view plugins sorted by Saved, In development, and Published.
From a Figma file
To access saved plugins from a Figma file, do one of the following:
- Navigate to the File menu in the top-left corner and select Plugins > Saved plugins
- Right-click anywhere on the board or editor and select Plugins > Saved plugins
- Click to open the Resources modal, select the Plugins tab, and then select Saved from the dropdown menu
Note: If you are a member of an organization, admins can restrict which public plugins you can use. When an organization admin enables the plugins approval list, you will not be able to use any unapproved plugins. You can still use existing plugins that you have saved in your personal space. Reach out to your organization admin to request a plugin for approval.
Remove saved plugins
When you remove a saved plugin, Figma immediately removes it from your account. You can always search for and save the plugin again if you change your mind.
Remove saved plugins by doing one of the following:
- Click next to the plugin.
- Select Remove from saved plugins.
From a Figma file
- Click to open the Resources modal.
- Select the plugin you want to remove.
Contact plugin developers
Figma does not provide support for third-party applications. If you have questions about, or issues with a plugin, we recommend reaching out to the developer.
Every plugin developer must provide a support contact. This can be an email address, a website, or a link to a help center.
Access the plugin’s support contact information by doing one of the following:
- Click next to the plugin and select Show details.
- Scroll to find the Support contact in the details.
From a Figma file
- Click on a plugin to view its details.
- Click See more details in Community.
Report a plugin
Report plugins that are inappropriate, or look suspicious, to the Figma team.
- Open the plugin listing.
- Click the Flag as inappropriate link on the right-hand side.
- This will create a new email message on your computer's default email app. Add details of your report in your message.
- When you're finished, send your email message to our plugins review team to review your feedback.
