Approve organization widgets
Who can use this feature
Supported on the Organization and Enterprise plans.
Only organization admins can manage approved widgets.
Organization admins can control which widgets members can use in organization FigJam files.
When enabled, members can only install and run widgets that are on the approved list. This includes any widgets members installed before the setting was enabled.
Members can still view widgets outside this list in files outside the organization.
Learn how to create private widgets →
Enable approved widgets list
- Open the organization Figma.
- Select Admin settings in the sidebar and click the Settings tab.
- In the Other section, toggle on Approved widgets.
Add approved widgets
Adding a widget to the approve list allows organization members to install and run these widgets in organization FigJam files.
Note: There isn't currently a way for members to request an approved widget in Figma. Members will need to contact an organization admin directly to add a widget to the approve list.
- Go to the widget listing that you want to approve.
- Click Copy link in the Share section to add the widget URL to your clipboard.
- Select Admin settings in the sidebar.
- Select Resources at the top of the page, then select Approved widgets.
- Click to add a widget to the approve list.
- Paste the widget link in the field provided and click Add to confirm. Figma will add the widget to the list of approved widgets.
Remove approved widgets
Removing widgets from the approve list will prevent members from using the widget in an organization files. That applies to any files within the organization space.
Members can still use public widgets in their personal space.
- Click next to the widget and select Remove widget.
- Figma will remove the widget from the approve list.
Spotted a suspicious or inappropriate widget? Report the widget to the Figma team.
- Open the widget page and scroll to the bottom.
- Click the Flag as inappropriate link at the bottom of the page.
- Use the field provided to add any relevant details then click Send message.
