Below the alignment and distribution buttons at the top of the Properties Panel are tools for directly manipulating the location and dimensions of objects on the canvas. You can change the width, height, rotation, and border radius, as well as modify the x and y coordinates.
Scrubbable Inputs
You can always manually type in values, but scrubbable inputs are fun and help speed up your workflow.
  1. Select an object on the canvas
  2. Place your cursor over the lable next to the input and watch the cursor change. You can also place your cursor over the input field and use alt/option + click as well.
  3. Now click and drag to change the input value
If you're cursor needs to go off the screen, no worries, Chrome supports cursor wrap. This works if you're using Figma in a Chrome browser, or if you're using our desktop app
Scrubbable inputs also work when you need to add strokes, change the opacity, or blur effects.
You control the speed
Sometimes you may need to move objects ever so slightly. Sometimes you need to move them quite a bit. Here's a nice feature:
  1. Select a shape on your canvas
  2. Place your cursor over the x-axis input field
  3. Hold the Alt/Option key and click to activate the left/right cursor
  4. Drag the cursor over the canvas
  5. Now slowly drag the cursor up and down the canvas
You'll notice two things:
  1. The width of the cursor changes, and
  2. A visual indicator pops up on the screen (Scrubbing at 1/2, 1x, 2x, etc). This even works with the cursor wrap technology.
When the cursor is wider and you move your mouse left and right, the object moves along the x-axis in smaller increments.
When the cursor is narrower and you move your mouse left and right, the object will move along the x-axis in smaller increments
Rotating objects
You can rotate individual objects, Frames and Groups. There are a couple ways to do this.
  1. Select the element you wish to rotate on the canvas
  2. Place your cursor just outside the object handles to activate the rotation arrows
  3. Click and drag to rotate your image
You'll also see the degree of rotation change in the properties panel. Scrubbable inputs also work for rotating objects. Hover over the rotation icon to the left of the input and drag to rotate.
Adjusting the corner radius
A very common question we hear from users is, "How do I round corners?". You can use the corner radius feature on rectangles, stars, and polygons.
Rectangles
  1. Use the R shortcut and click and drag out a rectangle on the canvas
  2. If you mouse over the rectangle, you'll see the [square] corner handles for the bounding box of the shape, and four (4) additional circular handles inside the shape.
  3. Change the size of the shape with the outer handles
  4. Click and drag any of the inner handles to round all the corners
If you need to round a single corner, hold Alt/Option then drag an individual corner. When you do this, you'll notice a new section in the properties panel.
You can manually set each corner radius here. Just like CSS, the order of input boxes starts from the top left and goes clockwise. These inputs are also "scrubbable". Hover over each, hold Alt/Option and use a 2 finger scroll on your trackpad, or scroll your finger across your Magic Mouse.
When you drag the rounding handles back towards the outer bounds of the shape and release them, you'll notice a slight “bounce back” effect. This is by design. It ensures the rounding handle doesn’t interfere with the bounding box handles.  If you make the rectangle too small or zoom out, the corner rounding handles will vanish.
"Does the corner radius feature support nudges?"
Of course!
Dragging a corner handle will snap by the Small nudge amount, and holding the Shift key will use whatever Big nudge you have predefined.
Stars
With a star selected and moused over, you will see three (3) control handles inside the bounding box.
These allow you to adjust:
  1. Count: the number of points on the star
  2. Rounding: how sharp or rounded you want each point to appear
  3. Radius: a percentage representation
Polygons
With a polygon selected and moused over, you'll see two (2) control handles inside the bounding box that allow you which allow you to adjust:
  1. Count: the number of corners, or sides, to your polygon
  2. Corner radius: how sharp or rounded you want each point to appear
Did this answer your question?
