Link Dev resources to layers in Dev Mode
Dev resources are a great way for anyone to add external documentation that can help developers better understand and build a component. Dev resources can be linked to objects in Figma Design and are often related to the documentation or source code. Use Dev resources to:
- Link a GitHub file to a component for quick access to the source code
- Assign a Jira ticket to a specific part of a mockup
- Connect Storybook to view stories in Figma
Note: If an attached dev resource has a related plugin available, clicking the link will automatically launch it in the Plugins tab.
Link to a Dev resource
Dev resources can be added to any layer on the canvas. If a dev resource is added to a component, the link is inherited by all instances of that component. If a dev resource is added to an instance of a component, the link will only appear for that instance.
To link to a dev resource:
- Copy the URL you want to add.
- In Dev Mode, select a layer on the canvas.
- In the inspect panel, click Layer options, and then Add a dev resource link.
- In the box that appears in the inspect panel, paste the link.
- Press Enter
Remove a linked Dev resource
- In the inspect panel, click Additional options next to the link to the resource.
- Select Delete link.
Note: Dev resources with related plugins may have different ways of detaching a link from a layer. Learn more about using plugins in Dev Mode.
