Who can use this feature
This article is for IT administrators configuring Figma on employee machines. You can configure the following desktop app settings via registry keys on Windows:
| Registry value | Description | Type | Value type |
| DisableUpdater | If set to 1, the updater will be disabled | REG_DWORD | Integer |
| AllowedOriginHosts | Domains that can be loaded within the Figma app, one per line | REG_MULTI_SZ | Multi-string value |
| ProxyUrl | If specified, all requests will be routed via this URL. http://, https://, ftp://, and socks:// schemes are accepted. For a direct connection, specify direct://. Advanced configuration options are available by using the proxyRules syntax documented here. | REG_SZ |
String |
The AllowedOriginHosts setting is a list of non-Figma domains that can be loaded in the app. For example, if https://*.example.com is on the list, the app will allow redirects to URLs on any subdomain of example.com.
Figma’s keys are located in HKEY_LOCAL_MACHINE\SOFTWARE\Figma. Keys stored in the HKEY_LOCAL_MACHINE namespace apply to all users on a computer.
