Project overview
- Product: Figma Design
- Topics: Auto layout, components, variants
- Difficulty: Intermediate
- Length: 20 minutes
In this project, we’re going to design a customizable tooltip component set. Tooltips are brief, informative messages that appear when a user interacts with the object they are attached to, such as icons, text links, or buttons. They’re useful when you want to provide extra information about the paired object.
Once you’ve completed this project, you’ll have a tooltip component set that covers the four major positions (top, right, bottom, left), as well as the eight minor positions, such as top-right and bottom-left. The tooltip will also grow or shrink in size depending on the length of content inside. Your final component set will have 12 variants and will look similar to the following:
Create the main tooltip component
To kick things off, we’ll create the main tooltip component. This component will consist of three layers:
- A text layer that will contain the tooltip’s content
- A triangle that will serve as the tooltip’s arrow
- A frame that will contain the arrow and text layers
Create the text layer
- Select the Text tool in the toolbar, click on the canvas, and type “Tooltip”.
- Select the text layer and change the font size to
13in the Typography section of the right sidebar. We’re using the default Inter font for this tutorial but feel free to pick something else. - In the Fill section, change the font color to
#FFFFFF. - With the text layer still selected, use the keyboard shortcut Shift A to apply auto layout.
- Select the text layer inside the new frame and change the Horizontal resizing to
Fill containerand the Vertical resizing toHug contentsin the right sidebar. - Select the frame layer and rename the layer to
Content. - Open the Width dropdown menu in the right sidebar and click Add max width.
- Set the max width to
250.
Why add a max width?
Tooltips are meant to be concise and helpful. Tooltips can span multiple lines, but keep your lines short and scannable. Adding a max width to the Content layer prevents the tooltip from stretching across the screen and blocking other content.
- With the Content layer still selected, set the auto layout properties to the following:
- Set the Horizontal resizing and Vertical resizing to
Hug contents - Change the Flow to
Vertical - Change the Alignment to
Align left - Change the Vertical gap between items to
4 - Change the Horizontal padding to
12 - Change the Vertical padding to
8
- Style the frame by adjusting the following settings:
- Click the plus in the Fill section to add a fill
- Change the fill color to
#000000 - Change the corner radius to
7
Before moving on, check to make sure your frame looks similar to the following:
Create the arrow
- From the Shape tools dropdown in the toolbar, select Polygon.
- Click on the canvas to add a polygon.
- Select the polygon and press Enter to open vector edit mode.
- Select the top point of the triangle and change the corner radius to
1. - Press Enter again to exit vector edit mode.
- Change the triangle’s width to
12and height to8. - Change the triangle’s fill color to
#000000. - Rename the layer to
Arrow. - Hold Shift and rotate the arrow 90 degrees.
- Center the arrow on the left side of the Content layer.
Add the layers to a frame
You’ll notice that the Arrow and Content layers are not grouped. If we turned these layers into components now, each layer would become an individual component. To connect the layers, we will add the layers to a frame:
- Select both layers, then right-click on the selection and choose Frame selection.
- Rename the frame to
Tooltip/left.
Before moving on, check the left sidebar to make sure the Arrow and Content layers are nested under the new Tooltip/left layer.
Now we need to apply auto layout to the Tooltip/left frame.
- Select the Tooltip/left frame and press Shift A to apply auto layout.
- Make sure the Clip content checkbox is deselected in the right sidebar.
- Set the following auto layout properties:
Hug - Change the Flow to
Horizontal - Change the Alignment to
Align center - Change the Horizontal gap between items to
0 - Change the Horizontal padding to
0 - Change the Vertical padding to
0
- Style the frame:
- Click the plus in the Effects section to add a drop shadow
- Select the drop shadow and change the blur to
16
- With the frame still selected, click Create component to turn the tooltip into a main component.
Why add a drop shadow?
Applied correctly, drop shadows create a sense of depth and hierarchy on the screen. They can help gently guide the user’s eye to interactive or important elements.
You might be wondering why we applied the drop shadow to the parent frame, rather than to the Arrow and Content child layers. Drop shadows on parent-level frames are applied evenly to the child layers inside the frame, making it appear as if the layers are a single object. If we were to apply a drop shadow to each child layer, or to a group of layers, the effect would be much less seamless.
Before moving on, check to make sure your tooltip looks similar to the following:
Create the major direction tooltip variants
Now that we have our main component, we can use it to add the top, bottom, and right tooltip variants to our component set.
First, we’ll configure the right variant:
- Select the component you just created.
- Click Add variant in the toolbar to add a variant.
- In the new variant, select the Arrow layer.
- Drag the arrow to the right of the Content layer or press the right arrow key on your keyboard.
- Right-click on the arrow and select Flip horizontal or use the keyboard shortcut Shift H.
- Select the new variant again. In the Current variant section in the right sidebar, type
arrowDirectionin the Property field andrightin the Value field. Now, all variants added to this component set will have thearrowDirectionproperty.
Now we need to create the top and bottom variants.
- Select the component set and click the purple plus to add another variant.
- Select the new variant.
- In the Auto layout section in the right sidebar, change the layout flow to
Vertical layout. - Select the arrow and hold Shift while rotating it until it points down.
- Select the variant and change the
arrowDirectionproperty value tobottom. - Repeat the process for the
topvariant.
Before moving on, make sure your component set has four variants.
Create the minor direction tooltip variants
All that setup we went through will make it a lot easier for us to create the eight additional variants needed to complete our component set. Creating the minor direction variants will involve moving the arrow’s position and changing the corner radius.
- Select the
leftvariant. - Click the purple plus below it to add another variant.
- Type
leftTopin the arrowDirection property value field. - In the Auto layout section, change the alignment to
Align top left.
Now, we need to modify the corner radius in the top-left corner so that the arrow blends in with the Content layer.
- Select the Content layer in the new variant.
- Select Independent corners in the right sidebar.
- Change the top-left corner’s radius to
0.
The variant looks much better without that rounded corner.
Now we can add the final variant for the left-facing tooltips.
- Select the
leftTopvariant and click the purple plus to add another variant. - Select the new variant and type
leftBottomin the arrowDirection property value field. - In the Auto layout section, change the alignment to
Align bottom left. - Select the Content layer of the new variant and click Independent corners in the right sidebar.
- Change the top-left corner radius to
7and the bottom-left corner to0.
Repeat the process for the remaining variants. As you add new variants, be sure to add corresponding values to the arrowDirection property value field. For example, topRight, bottomLeft.
Your final component set should look similar to the following:
What’s next?
Congratulations! Your customizable tooltip component set is ready to be used in your designs. If you’re looking for another challenge, modify your component set to include another variant property for an optional description field. If you design something you're extra proud of, we'd love to see it! Mention us on X (formerly Twitter) @Figma or publish it to the Figma Community.
Additional resource
Grab a copy of the Collection companion: Components file for hands-on practice with examples and other projects from Figma's components collection.
