You can access and use Adobe fonts in both the browser and the Figma desktop app. There are a few things to keep in mind when using Adobe fonts in Figma:
- If you’re working in the same file with collaborators, they’ll need to install the same font and version of the font to their computer
- Some versions of Adobe apps require you use the fonts and applications on your computer on a regular basis in order to keep them working on desktop apps like Figma
- We recommend restarting your Adobe and Figma app, or reloading your browser tab, after installing new Adobe fonts
Add Adobe fonts to Figma Design
1. Download Adobe fonts to your computer
To access Adobe fonts in Figma Design, you’ll need to add them to your computer using Adobe Fonts. Follow Adobe’s steps to add fonts to your computer →
2. Access Adobe fonts in Figma Design
To access Adobe fonts using Figma in a supported browser, you need to install the Font installer before you can add use Adobe fonts in Figma Design files. If you're using the Figma desktop app, the font installer is already included in the app.
After installation, reload any open files in your browser to start using the font.
Note: The Figma font installer, FigmaAgent, runs an HTTP and HTTPS server on localhost. It only allows connections from figma.com and isn't exposed to the public internet.
You may see events related to the FigmaAgent in your console log or when monitoring activity on your computer. The loopback address for localhost resolves to 127.0.0.1.
You can always uninstall the font helper if you need to, but will lose access to local and Adobe fonts on your computer.
Troubleshoot missing Adobe fonts
The font is missing
The text layer is using a font you don't have installed. The font could have been used by a collaborator or a different device with the font installed.
How do I check if this is my issue?
Reference the Adobe Fonts app to make sure the font installed on your computer. If the font or Adobe app hasn't been used recently, the font may need to be reinstalled.
How do I fix it?
Add Adobe Fonts to Figma Design by following the steps in Adobe Learn and Support →
You haven't used Adobe fonts or apps recently
Adobe’s products require they be used or relaunched after a set amount of time has passed in order to keep using the font on your device.
Reference Adobe Fonts to see if the font you’re missing needs to be reinstalled. Look for a cloud icon next to the font name in your font list.
How do I fix it?
Install the font to your computer, then restart your browser, Figma desktop app, Adobe CC/Adobe Fonts, and also your computer if you haven't done so recently.
There are conflicting versions of the font being used
If this only affects existing files you work on with multiple editors or on multiple devices you may see conflicting fonts.
Check if you can see this font available in the font picker in a new file in the desktop app.
How do I fix it?
To resolve conflicting font issues, all editors in the file need to:
Update the font
- Uninstall and remove the local font from their computer.
- Download and install the font from one common source.
- Restart the desktop or browser app.
Update affected layers
- Select a layer using that font.
- Click to open the main menu.
- Go to Edit > Select all with > Select all with same font.
- Open the quick actions menu and type Recompute Text Layout in Selection to reset text to the correct formatting.
