Before you Start
Who can use this feature
Available on any plan
Anyone with can edit access to a slide deck can skip or unskip slides
If you don’t want a slide to play during your presentation, you can skip it. This is useful for when you have multiple versions of a slide deck, but only want to present one. Skipped slides can still be moved and edited like any other slide.
Note: Skipped slides are not included when you export a slide deck to PDF.
To skip a slide:
- Select the slide you want to skip.
- Right-click on the slide and select Skip slide.
A closed eye icon will appear on the slide preview, indicating that it is hidden. To unskip a slide, right-click on a skipped slide and select Unskip slide.
