Note: Figma’s AI features are currently free while in beta, but usage limits may apply. When made generally available, Figma AI will become a paid feature. We’ll update you on pricing before that happens.
Before you start
Who can use this feature
Available in FigJam and Figma Slides
Available on paid plans
Requires can edit file access
After hosting an engaging team brainstorm or user research session in FigJam, you may have a lot of content to sift through before you can share your findings in a Figma Slides deck. With Figma AI, you can generate a slide deck outline from a FigJam board, giving you a good starting point that you can use to build the rest of your presentation.
Generate a slide deck outline
You can generate a slide deck outline from any FigJam board you have can view
access to. There are a few ways to generate a slide deck outline:
From Figma Slides
- Click New slide in the left sidebar to open the template picker.
- Click Start with an outline.
- Choose a FigJam board to summarize.
- If the FigJam board you selected has multiple pages, use the dropdown menu to select a specific page or choose All pages to summarize the entire board.
- Click Next.
- Select a template to use for the deck or click Create outline without template.
Figma AI sorts and summarizes the content on the FigJam and generates a slide deck outline. You can modify the generated slides and add additional slides to the deck, as needed.
From FigJam
- Open the board you want to use.
- Do one of the following:
- Go to Main menu > File > Create Figma Slides outline
- Click More actions next to a page and select Create Figma Slides outline
- Click Share in the top toolbar and select Create Figma Slides outline
- Select sticky notes on the board, right-click and select Create Figma Slides outline
- You’ll be redirected to the template picker in Figma Slides. Select a template to use for the deck or click Create outline without template.
Figma AI sorts and summarizes the content on the FigJam board and generates a slide deck outline. You can modify the generated slides and add additional slides to the deck, as needed.
