As a developer, when you’re reviewing designs in Dev Mode, you’ll encounter color, number, string, and boolean variables. The values of those variables can be dependent on things like the variable mode, which sometimes makes it harder to identify the exact values you want to pull from the design.
Figma provides a few options in Dev Mode to make working with variables easier for developers:
Variable details
When you're inspecting a design in Dev Mode, you can view details about variables used in the design. The Variable details modal lists information about a variable including:
- The name of the variable
- A link to the file that hosts the variable
- The name of the variable collection that contains the variable
- The variable’s mode
- The variable’s value and, if relevant, the chain of aliases to a raw value
- The scope of the variable (where it can be used)
- A code snippet for using the variable
A useful feature is the ability to follow the a chain of variable aliases back to a specific value. For example, in the previous image, the Background/Positive/Default variable uses Green/500 as an alias, which corresponds to the color value #14AE5C.
Using the Variable details modal, you can also change modes, letting you see the other values the variable can have.
Open the Variable details modal
There are two ways to open the Variable details modal:
For variables that appear in a code snippet, such as design tokens in CSS, click on the variable name in the Inspect panel to open the Variable details modal.
For other variables, such as those that appear in the Selection colors section, click Variable details in the Inspect panel to open the Variable details modal.
Suggested variables
In Dev Mode, when you’re inspecting a design, you’ll sometimes encounter raw values rather than variables or styles. This can happen for a number of reasons, such as if a designer happened to detach a variable during the design phase. When you encounter a raw value, you may want to see if there’s an existing variable that should be used instead.
To help make identifying corresponding variables easier, Dev Mode can suggest variables.
To suggest a variable, the variable must have:
- Exactly the same value
- The appropriate scope
You can click a suggested variable to copy the name.
Get suggested variables
To get suggested variables for a value in Dev Mode, in the Inspect panel, click the value you want to get a suggestion for. The Suggested variables modal appears next to the value you clicked.
Access local variable collections
In Dev Mode, you can access and view the local variable collections in the file.
The Variables modal is a read-only version of the Variables modal provided in Figma Design. For example, in the previous image, the Collection 1 variable collection is displayed in the modal.
You can click on individual variables and values to copy them to your clipboard and to view details about the variable.
Open the Variables modal
When you have no layers selected in Dev Mode, you can open a read-only version of the Variables modal provided in Figma Design. To open the modal, in the Variables section of the inspect panel, click Open variables table. The read-only Variables modal appears.
Variables in Dev Mode vs. Design
To best provide properties and values as code in Dev Mode, the way a variable is represented is sometimes adjusted.
Font Weight
Font weights in CSS can be represented by either strings or numbers. Similarly, in Figma Design, you can provide string variables as the weight for fonts.
In Dev Mode, string variables for font weight aren't provided. If the value of the string variable matches a valid weight for a given font, then the corresponding font weight is provided as a number in Dev Mode.
For example, suppose you have a text layer that uses Inter as the font:
- In the first scenario, you apply a number variable with the value
100as the font weight. You name the variableThin-100. In Figma Design,100corresponds to a valid font weight (Thin) for Inter. When you inspect the layer properties or view the code in Dev Mode, a reference to the variable is provided:font-weight: var(--Thin-100, 100); - In the second scenario, you apply a string variable with the value
Thinfor the font weight. In Figma Design,Thincorresponds to a valid font weight (100). In Dev Mode, when you inspect the layer properties or view the code, a reference to the variable is not provided:font-weight: 100;
In the second scenario, if the string variable matches a valid font weight for a font, the corresponding number is provided. If there is no corresponding number (that is, the string doesn't match a valid weight for the given font), Dev Mode falls back to 400: font-weight: 400;
Variable names
To maintain valid CSS, Dev Mode normalizes variable names in code. For example, suppose you have a variable named 🔵 Blue
0000FF. When you're viewing code in Dev Mode, the property name is rendered as --blue-0000FF.
