Figma Sites was released in open beta at Config 2025. Learn more about what’s included in the beta.
Who can use this feature
Starter, Professional, Education (not K-12), Organization, and Enterprise plans
In web design, breakpoints mark specific screen widths where your webpage layout changes to meet the needs of different screen sizes.
Every new webpage in Figma Sites starts with a desktop breakpoint. By adding additional breakpoints, you can fine-tune the look and feel of the webpage and optimize the user experience across devices.
For example, you might use multiple breakpoints to adjust cosmetic elements of the site, like resizing text for different devices. You can also modify functionality—like replacing a hover effect on desktop with a press effect on mobile, since mobile devices don’t support hover interactions.
Tip: When you make edits to the primary breakpoint, they automatically cascade to other breakpoints. Learn more about editing across breakpoints.
How breakpoints work in Figma Sites
Let’s say you have a desktop breakpoint 1280px wide, a tablet breakpoint 800px wide, and a mobile breakpoint 340px wide.
- A screen width over 1280px will use the desktop layout
- A screen width between 800px and 1280px will use the tablet layout
- A screen width under 800px will use the mobile layout
Add a new breakpoint
Tip: We recommend using auto layout in your designs. Auto layout simplifies the design process by allowing your content to reflow seamlessly across different screen sizes, reducing the need for manual adjustments. Learn more about working with auto layout.
To add a new breakpoint to a webpage:
- Click the plus button in the webpage header on the canvas.
- Choose a desktop, tablet, or mobile breakpoint with predefined widths, or enter a custom breakpoint width.
If your designs use auto layout, Figma will automatically adjust the layout so it flows better in the new breakpoint size. For example, Figma will adjust the padding to account for content areas that are too narrow, or convert horizontal layouts to vertical if there is not enough width available.
Edit breakpoints in a webpage
You can adjust your webpage’s breakpoints simply by changing the width of each one.
When you change the width of a breakpoint, its neighboring breakpoints automatically adjust the range of sizes they cover. To edit the breakpoint width:
- Select the breakpoint you’d like to change.
- Enter a new width in the right sidebar.
Delete a breakpoint
Deleting a breakpoint causes the remaining ones to adjust automatically.
For example, if you delete a tablet breakpoint between a desktop breakpoint and a mobile breakpoint, the mobile breakpoint will then apply at screen widths below the desktop breakpoint.
To delete a breakpoint, select it on the canvas or in the layers panel and press delete.
