Who can use this feature
Users with Full seats can chat with the agent in Figma Design and Figma Make files
Users with View, Dev, or Collab seats can try the agent in Figma Design and Figma Make files in Drafts
The Figma agent and Figma Make can connect to external tools via the Model Context Protocol (MCP), allowing you to work with documents, tasks, and data from other apps as context for your designs, apps, and prototypes.
For example, you might connect Figma Make to Notion to import a product requirements document (PRD) directly into Figma’s chat and ask Make to use it as the source for building a prototype. If the PRD changes, simply run the connector again to refresh the context and update the prototype. You can also write content back to Notion—like generating a list of acceptance criteria—by enabling the write tools in the connector’s settings.
What’s the difference between MCP connectors in Figma and the Figma MCP server?
When you connect external tools in the agent or Figma Make, it acts as an MCP client. The client calls tools hosted on an MCP server—for example, the Notion or Asana connectors—to read or write data from that source. Based on your prompt, the agent decides which connector and tools to use.
By contrast, the Figma MCP server includes a list of tools that makes your file data available to other MCP clients.
Add a connector
Each person needs to add and authenticate the connectors they’d like to use.
To add a connector, you’ll first need to authenticate. For example, when adding Notion, you’ll select your workspace and approve access permissions.
- From the chat box, click Add context.
- Select Connectors .
- Browse the list of available connectors.
- Click Connect next to the connector you want to use.
- Follow the prompts to authenticate through the external tool’s OAuth flow.
- Once connected, click Add context to confirm the connector appears in the list.
Tip: If you don't see a prompt to authenticate, your browser may be blocking popups. Check your browser's address bar for a popup blocker icon and allow popups for Figma.
Note: If Connectors isn't an option in the menu, an admin may have disabled this feature for your organization.
Use a connector in chat
When a connector and its tools are enabled for the current chat, you can call it naturally within the flow of conversation.
- To explicitly reference a connector in your prompt, type @ in the chat to see a list of your connected connectors. Select the one you want to use, and it will appear as a pill above your message. This makes sure the agent only uses specific connectors for the current task.
- Type a prompt that references the connector. For example, paste an Asana link and write "Use the specs in this project to create a first-draft prototype".
- If your prompt requires a connector, the agent will show which connector and tool it plans to call and ask for consent. Click Run to proceed. You can manage individual tools and their permissions from the connector settings.
If the source content changes, just run the connector again to pull in the latest context.
When a connector tool is set to Always run, file downloads may fail if the response exceeds 16 MB. For text files, this generally corresponds to a file size of up to 16 MB. Images larger than approximately 5–6 MB may exceed the limit because image encoding increases the response size. This applies to all connectors in the Figma agent and Figma Make. If a large image fails to download, set the tool to Ask to run and try again.
What featured connectors are available
Figma currently supports a limited set of verified connectors. These featured MCP servers have been vetted by our team to ensure they meet Figma’s security and privacy standards.
Note: You must have an account with the external service to use the related connector. Availability may depend on your plan, seat, role, or access within that service.
Figma provides the following featured connectors:
Tip: Need to connect to an MCP server that’s not on this list? You can create your own custom MCP connector. Custom MCP connectors require a paid plan.
Amplitude
- Access Amplitude user trends, funnels, and experiments within Figma to generate designs and prototypes with product context.
- Create and test design variants to track impact on user behavior.
Asana
- Access Asana tasks and projects from Figma to track progress and team priorities in real time.
- Create and manage Asana tasks, so you can keep projects aligned from concept to completion.
Askable
- Access your research findings from Askable inside Figma.
- Query your evidence and ground prototypes in what verified participants actually said and did.
Atlassian
- Access and edit Confluence pages and documentation directly from Figma to keep specs, decisions, and design work connected.
- Access, create, and transition Jira issues and epics without context switching, so teams can move smoothly from design to development.
- Access, create, and update Compass components, services, and scorecards to keep designs and prototypes linked to your engineering ecosystem.
Box
- Access hubs and content from Box during your design process, while enforcing existing Box security and access policies.
- Extract key insights and query all of your content, to ground your prototypes in your enterprise context.
Contentsquare
- Access Contentsquare analytics from Figma, including user journeys, funnels, and page metrics.
- Query how people use your live product to ground design decisions in real behavior. The connector is read-only.
Dovetail
- Access Dovetail customer data in Figma to inform design decisions.
- Search across your Dovetail workspace to find relevant projects, data and docs.
Google Drive
- Access files across your Google Drive directly from Figma to ground your design and prototypes in your team's existing research, data, images, or other context.
- Create new files in Google Drive from Figma to summarize decisions and upload assets, making it easier to share where your team already works.
Note: The Google Drive connector is not available when using the Governance+ add on.
Granola
- Connect Figma to your meeting history in Granola
- Search through your meeting notes, find specific topics discussed in past meetings, extract action items or decisions from your notes, answer questions based on your meeting history and more.
GitHub
- Access public or private GitHub repositories, issues, and pull requests to keep design work tied to your codebase.
- Create and summarize GitHub issues and PRs from within Figma, so design changes translate directly into development action.
Hex
- Bring in Hex dashboards and data apps, and ask data questions via Hex threads.
- Build data into your presentations, designs, and boards.
Linear
- Access Linear issues, projects, and documents from Figma to generate designs and prototypes with relevant context.
- Create and manage Linear issues and projects, so you can turn your designs and prototypes into planned work.
Mapbox
- Add a live, interactive Mapbox map to your Figma Make prototype.
- Generate real-world locations from the Mapbox Streets v8 tileset with the Figma agent.
- Style maps to match your brand and check them for accessibility.
Marvin
- Access Marvin directly within Figma to ground your designs in real user feedback and data.
- Generate summaries of customer knowledge, so you can design with confidence and validate prototypes faster.
- Requires Marvin Enterprise plan and Contributor or Admin role in Marvin.
Mobbin
- Pull screens and patterns from Mobbin into your workflow for research and reference.
- Use Mobbin references and combine them with your design system to jam on design ideas.
- Compare your designs in Figma against Mobbin benchmarks.
monday.com
- Access monday.com boards and items from Figma to stay aligned with team planning and priorities.
- Create and manage updates, so your work stays visible and connected across every team.
Notion
- Access Notion pages and databases directly from Figma to bring context, specs, and notes into your design flow.
- Create and update Notion docs, so your design documentation stays organized and always in sync.
Slack
- Search and read Slack messages, threads, channels, users, and files.
- Take action by sending messages and creating canvases and channels.
Sprig
- Access customer surveys within Figma to ground designs and prototypes in evidence.
- Create and launch Sprig studies to test designs, concepts, and prototypes created with Figma and measure how users respond to them.
Twilio
- Access Twilio's API documentation from Figma to build communication features like messaging, voice, and verification into your prototypes.
- Generate accurate, up-to-date code for Twilio APIs without leaving your design flow. The connector provides API knowledge and does not send messages or access your account data.
Zapier
- Connect to Google Drive, Microsoft Office, Zoom, Jira, HubSpot, Slack, and 9,000+ other apps through a single connection.
- Bring the context from your tools directly into your design and prototyping workflow: pull a requirements doc, a spreadsheet with real data, or meeting summaries. Then go further and create tasks, send messages, and trigger workflows across your entire tool stack from a single prompt.
zeroheight
- Power Figma with design system context from your zeroheight styleguide to generate on-system prototypes in seconds
- Use the Figma to stress-test your zeroheight docs. AI misinterpretations can reveal unclear guidance and help you prioritize improvements.
- Requires zeroheight Enterprise plan and access to the DS team with an Editor or Admin seat. Documentation viewers can create a custom connector to access the zeroheight MCP server.
Note: Interested in connecting your product to Figma? We’re currently collecting expressions of interest for new partnerships. If that sounds like you, please share a few details about your product and use case with us.
Manage connector settings
Some connectors include multiple MCP tools. These tools perform different functions within the connector, such as fetching data, sending updates, or managing content.
You can control which tools are available in Figma; for example, you may want to allow a tool that fetches content, but disable tools that send content back to the external source.
Note: Tools that can write to external sources are disabled by default. You’ll need to manually enable them before you can send content back to the connected service.
You can also control each tool’s permissions within a connector. The available options are:
| Setting | How it works | When to use it |
| Ask to run | Figma always asks your permission before running the tool | You want control every time the agent runs a tool in the conversation |
| Always run | Figma runs the tool when needed without asking for permission | You trust the external source and the available data |
| Never run | Figma won’t attempt to run the tool | Use this setting for tools you don’t need; it can help speed up Figma AI by giving it a smaller set of tools to choose from |
Caution: Be wary of prompt injections from external sources when pulling in context.
You can also temporarily disable connectors to ensure they aren’t used in the current conversation.
- From the chat box, click Add context. Hover over Connectors, then select Manage.
- Click Manage on the connector.
- Enable or disable the read or write tools, or set permissions for individual tools within that connector.
Tip: Only enable the relevant connectors—and their tools—to help the agent work faster.
Disconnect a connector
Disconnecting a connector stops the Figma agent and Figma Make from reading or writing data through it. It doesn’t delete any data in the external tool, and you can reconnect later by adding and authenticating it again.
- At the bottom of the modal, click Disconnect.
