Before you start
Who can use this feature
Supported on any team or plan
Anyone can rename their own files in their drafts
Only team admins or members with edit access can rename team files
Rename files and folders to explain their purpose or contents. Set a file or folder name when you first create it, and update it as needed.
Rename a file
Figma names every new file you create as Untitled. You can change this to something that better explains the contents of the file.
File names don't need to be unique, but unique names make it easier to search for and find the correct file.
You can update the file name the following ways:
- Right-click the file in the file browser.
- Select Rename from the file menu.
- Figma displays the file's location and name at the top of the left sidebar.
- Click on the existing file name to edit the name.
- Click outside of the field or press Enter to apply your changes.
Rename a folder
- Open the folder in the file browser.
- Click the down arrow next to the folder name > Settings.
- Rename your folder.
