Animations can be used to create smooth transitions between pages and define the behavior for actions like expanding a menu, swiping between pages, or opening a gallery.
New to Prototyping? Check out our Getting Started with Prototyping guide.
Instant
The Instant transition will immediately display the Destination Frame, when the hotspot is interacted with (clicked, hovered over, or pressed).
Dissolve
The Dissolve transition will fade in the Destination frame, on top of the original frame.
Supports:
- Duration
- Easing
Smart Animate
Smart Animate looks for matching layers that exist across multiple frames. For layers that match, we recognize what's changed and apply transitions to seamlessly move between them.
Supports:
- Duration
- Easing
Move In / Move Out
The Move transition will slide the Destination frame into or out of view, above the original frame.
Supports:
- Easing
- Direction
- Duration
Push
The Push transition will push out the original frame, as the Destination frame is moved into view. This is the perfect transition for replicating a swiping gesture.
Supports:
- Direction
- Easing
- Duration
Slide In / Slide Out
The Slide will move the Destination frame into or out of view. Slide will slowly offset the frame as it dissolves, while the Move transition keeps the original frame stationary.
Supports:
- Direction
- Easing
- Duration
Tip! Use prototype easing and spring animation curves to give your animations a unique and natural feel.
