A CMS list is a repeating design block that displays multiple items from a collection. It provides a simple, dynamic way for visitors to browse your content, and it updates automatically as new content is added to your collection.
Common examples of CMS lists include:
- Recent blog posts
- Customer testimonials
- Team profiles
- Features and benefits
What’s the difference between a CMS page and a CMS list?
Suppose you’re working on a cooking website with lots of recipes.
A CMS list displays multiple items from a collection—like a grid of recipe previews with titles, images, and short descriptions. Visitors can browse through the list to find what they’re interested in.
A CMS page shows all the details for a specific item: the ingredients, steps, and photos. Each CMS page uses the same design template, but the content updates automatically based on the selected recipe.
How it works
A CMS list has two parts:
- A main component that controls styling of the repeating list elements.
- A CMS list layer that contains repeating instances of the component. The child layers of these instances are connected to fields in your CMS collection.
There are two main ways to create a CMS list:
Insert a pre-built CMS list block
Note: You’ll need to create a CMS collection before you can add CMS blocks.
If you don’t have a design yet, you can drop in a pre-built CMS list block. This block includes a main component and a CMS list layer with instances of the component inside. The layers are already connected to fields in the collection.
- Click Insert from the left navigation bar.
- From the Blocks tab, click CMS.
- Drag a CMS list onto the canvas for the relevant collection.
When you edit the main component, all instances within the CMS list layer update automatically.
Create your own CMS list
The easiest way to convert a design into a CMS list is from Connect view.
- Click CMS in the left navigation bar.
- Select the Connect tab.
- Hover over a collection, click Connect, then choose Part of a page.
- Select the parent frame on the canvas.
There are a few additional ways ways to convert a design, depending on its structure:
A parent frame with repeating child layers
- Select the parent frame.
- In the right sidebar, click Connect to CMS and select a collection.
What happens:
- The parent frame changes to a CMS list layer.
- Figma generates a new main component of the repeating layers if one doesn’t exist already.
- The repeating layers become instances of the component.
A frame containing a design you want to repeat
- In the right sidebar, click More.
- Select Connect to CMS, then select a collection.
What happens:
- Figma turns the frame into a main component if it isn’t one already.
- Figma creates a CMS list layer and populates it with instances of the component.
Two identical layers
- Select any two identical layers.
What happens:
- Figma wraps the layers in a new CMS list layer.
- Figma generates a new main component based on the identical layers if one doesn’t exist already.
- The identical layers become instances of the component.
Note: If you create a CMS list from design elements in a webpage with multiple breakpoints, Figma will create a component variant for each unique design. This helps you style the list for different devices and screen widths.
Learn more about creating and working with responsive components.
Note: It’s not possible to create a CMS list from designs in an auto layout grid flow.
Connect layers to CMS fields
Once you’ve created the CMS list, connect its layers to fields in your collection.
Note: You can only connect CMS fields to layers within a CMS page or in a CMS list.
Connect layers from the right sidebar
You can quickly connect layers from the right sidebar while working on the CMS list. This process is similar to working with variables.
Connect to a text layer
- Select a text layer in the CMS list. For text layers, make sure you select the actual text layer and not any parent layers, like a frame.
- At the top of the right sidebar, click Apply variable or CMS field, then select a field.
Connect to an image fill
You can connect an image field to any layer with a fill, like shapes and frames.
- Select a layer with a fill within the CMS list.
- In the Fill section of the right sidebar, click Add fill.
- Select the CMS tab, then select an image field in the collection to connect it.
Connect a link
You can connect a link field to any linkable element, like text, frames, or shapes.
- Select a layer within the CMS list.
- In the right sidebar, click Add link.
- Enter a link, or click the dropdown menu to select an existing webpage from your site.
Tip: This is how you link a CMS list to a CMS page.
Connect layers in Connect view
The Connect view lets you quickly wire up an existing layout or review what’s already connected. In this view, you choose a field, then select the target layer in the CMS list to connect it.
Note: Certain field types only connect to compatible layer types. For example, you can’t connect a text field to a shape or frame.
- Click a field in the collection, then click a target layer in the CMS list to connect it. All items in the list will automatically update.
- Repeat for additional fields and layers.
Note: You can only connect fields to layers in the CMS list, not the main component.
Tip: While in Connect view, double click a connected design on the canvas to edit the field values for the current item.
Set the number of items in the CMS list
By default, Figma includes all items in a collection in a CMS list—but you can limit the number if needed.
- Select the CMS list layer in the Layers section of the left sidebar.
- Select a value from the Limit property at the top of the right sidebar.
Note: Filtering or sorting a CMS list isn’t currently supported.
Reorder items in the CMS list
Reordering items in the table view of your collection updates their order across all CMS lists.
- Hover over the item whose position you want to change.
- Click and drag the icon at the very left of the row and move the item to a new position.
Link a CMS list to a CMS page
It’s common to link items in a CMS list to their corresponding CMS page. For example, you might create a list of blog posts on the Home page that link to each post. To add a link to a CMS list:
- Select the element in the list you want to turn into a link.
- From the right sidebar, click Add link.
- Open the dropdown menu and select the CMS page template you’d like to use. It will be listed under the name of the collection and have a URL path that ends with
/slug.
Remove a connection from the CMS list
To disconnect a layer in a CMS list:
- From the left navigation bar, click CMS and switch to the Connect tab.
- Click a connected layer’s annotation, then click Remove connection.
When you remove a connection, the disconnected layers will keep their content from the last known-connected state.
Tip: You can also disconnect a layer from the properties panel. Select it on the canvas, then click Remove connection in the right sidebar.
Frequently asked questions
Can I add a CMS list to a CMS page?
Yes. For example, you could add a CMS list at the bottom of a blog post to display a list of other posts to read.
What happens if an item has an empty field when connected to a layer?
- An empty text or date field causes the text layer to render with no content.
- An empty image field translates to an empty, transparent fill on the frame or shape. To make sure an image always shows, apply a fallback fill below the connected fill, so an image still appears if the CMS field is empty.
Why can’t I move layers out of a CMS list?
A CMS list is made up of component instances. The number of component instances is controlled by the CMS list layer. To change the number of items in the list, select the main CMS list layer and then adjust the limit property at the top of the right sidebar.
To update the design of layers in the list, edit the main component.
