Skills are pre-built instructions that teach your AI agent how to handle common Figma tasks reliably, such as creating a new file, building a screen from your design system, or generating code from a design. Without skills, you'd need to describe each step yourself every time. With them, you can ask your agent to do something like "create a new Figma file" or "implement this design" and it already knows what to do.
Note: This article describes the skills that Figma provides for the Figma MCP server. To learn about MCP skills and how to use them, check out Use skills with the Figma MCP server.
Figma provides a number of skills for use with the Figma MCP server:
- figma-use
- figma-use-figjam
- figma-use-slides
- figma-swiftui
- figma-code-connect
- figma-create-new-file
- figma-generate-diagram
- figma-code-workflows
- figma-spec
As well as two example skills that demonstrate how to write to the canvas in Figma:
Additionally, you can browse a collection of curated skills in GitHub.
Get the Figma skills
Figma plugin
The easiest way to get the Figma skills is through an agentic tool that supports the Figma plugin, such as Claude Code or Cursor. When you install the Figma plugin in one of these tools, the skills are included automatically.
The instructions for setting up the remote Figma MCP server describe how to get the Figma plugin for several common clients.
Download the skills
If your AI tool doesn't have a Figma MCP plugin, you can download and manually install the skills.
Click here to download the skills.
You can also view the skills in our mcp-server-guide repository on GitHub.
Once you've downloaded the skills, the easiest way to install them is to ask your AI agent to unzip the file and place the contents in the right folder for your tool. Your agent will know where skills are expected to live.
Troubleshooting
If you run into issues downloading or installing skills, see our Figma MCP server FAQs.
Use skills
You use the Figma skills for the MCP server the same way skills are generally used with Claude Code, Codex, and others. The exact way you invoke a skill depends on the client.
To learn more, see Use skills with the Figma MCP server.
Figma skills
This article dives into the skills that Figma provides and some example use cases, but don't think of the examples as the limits of a skill; they're just a way to get started!
The skills you'll use depend on the task you're doing.
figma-use, for example, is the foundational skill for anyone who wants to write content to a Figma canvas. The skill is used for creating frames, components, variables, and layouts directly in a file. Other skills build on top of it for more specific workflows.
Some skills, like figma-create-new-file and figma-generate-design, are useful for designers working directly with Figma files.
Others, like figma-code-connect and figma-code-workflows, are more relevant if you write code or are working closely with developers.
And figma-spec helps your whole team share project context with agents, so everyone builds from the same requirements.
figma-use
figma-use is the skill that powers write-to-canvas. When you want your agent to create or modify content directly in a Figma file, such as building frames, placing components from your design system, setting up variables, arranging auto layout, this is the skill that makes it possible.
Instead of generating a static image or a rough approximation, your agent uses figma-use to write real, editable Figma content: the same components, variables, and layout rules your team already relies on. The result lands directly on the canvas and is ready to inspect, refine, and extend.
You can write to any Figma Design file you have edit access to. To get started, share a Figma file URL or a link to a specific selection in your prompt, then describe what you want to create or change. For example:
- "Using this Figma file: <URL>, create a new page and build a settings screen using our existing components."
- "Using this selection: <URL>, add an empty state that matches the existing design system."
- "Using this Figma file: <URL>, convert the raw color values in this frame to variables."
When to use it: Use this skill any time you want your agent to create or modify content on the Figma canvas, whether you're building a new screen, updating components, or working with variables and tokens.
Requirements:
- A Figma Design file URL or a link to a specific selection
- Edit access to the file
See the whole skill on GitHub: https://github.com/figma/mcp-server-guide/blob/main/skills/figma-use/SKILL.md
figma-use-figjam
figma-use-figjam is the foundational skill for working with FigJam boards. When you want your agent to create or modify content directly in a FigJam file, such as adding stickies, sections, connectors, shapes, tables, or code blocks, this is the skill that makes it possible.
Instead of treating FigJam like a generic whiteboard, your agent uses figma-use-figjam to work with real, editable FigJam content and structure. The result lands directly on the board and is ready to review, reorganize, and build on with your team.
You can use it with FigJam boards you have access to through a supported MCP client. To get started, share a FigJam file URL or a link to a specific board in your prompt, then describe what you want to create or change. For example:
- "Using this FigJam file: <URL>, organize this brainstorm into sections and add stickies for the main themes."
- "Using this FigJam board: <URL>, create a planning board with sections, stickies, and connectors for this project brief."
- "Using this FigJam file: <URL>, update this architecture diagram with a new service and reconnect the related systems."
When to use it: Use this skill any time you want your agent to create or modify content on a FigJam board, whether you're organizing information, building a planning board, or refining a diagram.
Requirements:
- A FigJam file URL or a link to a specific selection
See the whole skill on GitHub: https://github.com/figma/mcp-server-guide/blob/main/skills/figma-use-figjam/SKILL.md
figma-use-slides
figma-use-slides is the foundational skill for working with Figma Slides decks. When you want your agent to create or modify content directly in a Slides file, such as adding slides, organizing them into sections, updating text and shapes on a slide, applying a theme, or writing speaker notes, this is the skill that makes it possible.
Instead of producing a static export or a one-off mockup, your agent uses figma-use-slides to write real, editable Slides content: actual slides in the slide grid, theme variables and text styles your team can keep building on, and speaker notes that show up in Presenter View. The result lands directly in the deck and is ready to present, refine, and extend.
You can use it with Slides files you have edit access to. To get started, share a Slides file URL or a link to a specific slide in your prompt, then describe what you want to create or change. For example:
- "Using this Slides file: <URL>, build a five-slide kickoff deck for this project brief."
- "Using this slide: <URL>, rework the layout to match the rest of the deck."
- "Using this Slides file: <URL>, add speaker notes for every slide that has substantive content."
- "Using this Slides file: <URL>, organize the deck into sections and name them."
When to use it: Use this skill any time you want your agent to create or modify content in a Slides deck, whether you're building a new presentation, reworking individual slides, or adding speaker notes.
Requirements:
- A Slides file URL or a link to a specific slide
See the whole skill on GitHub: https://github.com/figma/mcp-server-guide/blob/main/skills/figma-use-slides/SKILL.md
figma-swiftui
figma-swiftui translates between Figma designs and SwiftUI code in both directions. Use it to implement a Figma design as SwiftUI in your iOS project, or to push SwiftUI views and screens back into a Figma file.
The skill recognizes iOS patterns rather than rebuilding them from primitives. A Figma frame with a large title and back chevron becomes a NavigationStack, and a row of icon-and-label pairs becomes a TabView. SF Symbols round-trip by name in both directions, and semantic colors map to the iOS HIG tokens your team already uses (Color(.systemBackground), Color.secondary) rather than being inlined as hex values.
To get started, share a Figma file URL alongside your SwiftUI project, then describe which direction you want. For example:
- "Implement this Figma screen in SwiftUI: <URL>"
- "Build this in SwiftUI for iPad: <URL>"
- "Push the SwiftUI views in
Sources/Screens/Settings/into this Figma file: <URL>" - "Mirror this SwiftUI design system in Figma: <URL>"
If the request is ambiguous, such as a Figma URL appearing alongside .swift files with no clear verb, your agent will ask which direction you want before continuing.
When to use it: Use this skill any time you want to translate between a Figma design and SwiftUI code, whether you're implementing a screen for iOS or pushing existing SwiftUI views back into Figma.
Requirements:
- For pushing SwiftUI into Figma, edit access to the file
See the whole skill on GitHub: https://github.com/figma/mcp-server-guide/blob/main/skills/figma-swiftui/SKILL.md
figma-code-connect
figma-code-connect connects your published Figma components to their matching code implementations using Figma's Code Connect feature. Once connected, developers can open a component in Figma's Dev Mode and navigate directly to the corresponding code without having to hunt for it.
To use it, point your agent at a Figma selection or share a Figma URL containing the components you want to connect. The agent will scan your codebase for matching components, show you the proposed connections for review, and then create them in bulk once you confirm.
When to use it: Use this skill when you want developers in Dev Mode to be able to see code references linked from the design component to its implementation in the codebase.
Requirements:
- A Figma URL for the components you want to connect, or the components selected in the Figma desktop app
- Components must be published to a team library
- Professional, Organization, or Enterprise plan
See the whole skill on GitHub: https://github.com/figma/mcp-server-guide/blob/main/skills/figma-code-connect/SKILL.md
figma-create-new-file creates a new blank Figma file in your drafts. It works for both design files and FigJam boards.
Usage: /figma-create-new-file [editorType] [fileName]
Examples:
/figma-create-new-filecreates a design file named "Untitled" -
/figma-create-new-file figjam My Whiteboardcreates a FigJam file named "My Whiteboard" -
/figma-create-new-file design My New Designcreates a design file named "My New Design"
When the file is created, your agent returns a link you can open directly in Figma.
If your account belongs to multiple Figma organizations, your agent will ask which one to create the file under before proceeding.
When to use it: Use this skill whenever you need a fresh Figma file, typically as the first step before asking your agent to build something on the canvas with figma-use.
See the whole skill on GitHub: https://github.com/figma/mcp-server-guide/blob/main/skills/figma-create-new-file/SKILL.md
figma-generate-diagram turns a description of a system, process, or flow into an editable FigJam diagram. Describe what you want to diagram and your agent will produce a flowchart, sequence diagram, ER diagram, state diagram, or Gantt chart, and place it in a FigJam file you can keep editing.
Instead of generating a static image you have to redraw to change, your agent uses figma-generate-diagram to write a real FigJam diagram: actual nodes and connectors you can move, rename, restyle, and build on with your team. For diagrams that need annotations or color-coded sections beyond what the base diagram supports, the agent can extend it with stickies, shapes, and other FigJam content after the diagram is created.
To get started, describe the diagram you want, or point your agent at the source material it should diagram, such as code, a spec, or an existing file. For example:
- "Diagram the auth handshake between our web client, API gateway, and identity service as a sequence diagram."
- "Using the schema in this repo, generate an ER diagram of our core tables."
- "Create a flowchart of the onboarding steps in this PRD, and add stickies next to each step with the owning team."
When to use it: Use this skill when you want a diagram you can keep editing in FigJam, whether you're documenting a system, walking a team through a process, or sketching a data model.
Requirements:
- A description of what to diagram, or a link to the source material the diagram should be based on
See the whole skill on GitHub: https://github.com/figma/mcp-server-guide/blob/main/skills/figma-generate-diagram/SKILL.md
figma-code-workflows brings an existing project from your computer into Figma. Tell your agent what you want to end up with, and it picks the right tool and walks through the import:
- A code layer in a Figma Design file, so your running app sits on the canvas next to your designs
- A standalone Figma Make file, so you can keep building the app with the Figma Make agent
- Editable design layers in a Figma Design file, captured from a running app or converted from an HTML file
If you don't say which one you want, your agent asks before it starts. Your agent keeps you updated as it prepares, uploads, and imports the project, and shares a link to the result when it's done.
For example:
- "Import this project as a code layer in this Figma file: <URL>"
- "Bring this app into a new Figma Make file."
- "Turn this HTML page into editable design layers in this file: <URL>"
Imports can take 10 minutes or more. Some projects need changes to run in Figma, and your agent may need to adjust and retry the import.
When to use it: Use this skill when you've built something with your coding agent and want to keep iterating, collaborating, and sharing it in Figma.
Requirements:
- An existing project on your computer. This skill doesn't create new apps from a description.
- Edit access to the destination file
- To create a code layer, a Full seat and access to code layers
See the whole skill on GitHub: https://github.com/figma/mcp-server-guide/blob/main/skills/figma-code-workflows/SKILL.md
figma-spec
figma-spec lets your agent read, create, and update Figma Specs, whether it's a standalone spec or a spec embedded in a Figma Design or FigJam file.
Use specs to give your agent project context, like requirements, decisions, and open questions, before it starts building. As it works, your agent can capture decisions and discoveries back in the spec, so your team stays in sync. Your agent makes targeted edits instead of rewriting the whole spec, and keeps existing comments attached to the right text.
For example:
- "Read the spec in <URL> and implement the checkout requirements."
- "Draft a spec for the onboarding redesign in this FigJam file: <URL>"
- "Add the edge cases we found today to the open questions section of this spec: <URL>"
When to use it: Use this skill when you want your agent to work from your team's requirements, or to keep a spec up to date as the work changes.
Requirements:
- A link to a Figma spec, or to the Figma Design or FigJam file that contains it
- To create or update a spec, edit access to the file
Note: Figma Specs is in open beta. Support for spec comment workflows is coming soon.
See the whole skill on GitHub: https://github.com/figma/mcp-server-guide/blob/main/skills/figma-spec/SKILL.md
Example skills: Write to canvas
figma-generate-library and figma-generate-design are examples of what's possible when you build on top of figma-use. Each one shows how write-to-canvas can be combined with design system awareness and multi-step orchestration to tackle a larger workflow.
Both skills are fully functional and ready to use. They're also provided as references: if you want to build your own skill for a workflow specific to your team, these are good starting points to learn from and adapt.
figma-generate-library builds or updates a Figma design system library from your codebase. It works in phases: first understanding what you have (in both code and Figma), then creating token collections, building out component pages, and running a final quality check. It pauses for your review between phases before continuing.
The phases are:
- Discovery: Reviews your codebase and existing Figma file to understand what tokens and components are already there, then confirms scope with you before creating anything
- Foundations: Creates variable collections for colors, spacing, and other tokens; sets up text and effect styles
- File structure: Sets up standard pages (Cover, Getting Started, Foundations, Components, Utilities) with documentation for color swatches, type specimens, and spacing
- Components: Builds each component with variants, auto-layout, and variable bindings; validates with screenshots before moving on
- Integration and QA: Finalizes Code Connect mappings, checks naming and accessibility, and takes final screenshots
When to use it: Use this skill when you want to generate or sync a Figma design system library from your codebase, including themes like light and dark mode, token collections, and component libraries.
Requirements:
- Access to the project codebase
- An existing Figma file to build into (create one first with
figma-create-new-fileif needed)
See the whole skill on GitHub: https://github.com/figma/mcp-server-guide/blob/main/skills/figma-generate-library/SKILL.md
figma-generate-design builds full-page screens in Figma using real components, variables, and styles from your design system. Point it at a page or view in your codebase and it will find the matching design system assets, import them, and assemble the screen section by section.
For web apps, it can also take a live screenshot of the running application to use as a layout reference, helping it match the real proportions and spacing.
When to use it: Use this skill when you want to push a page, screen, or multi-section layout from your application into Figma.
Requirements:
- A Figma file with a connected design system, or a linked library
See the whole skill on GitHub: https://github.com/figma/mcp-server-guide/blob/main/skills/figma-generate-design/SKILL.md
