Transformation describes how an object changes its visual properties over the course of an animation. While easing, timing, and sequencing govern when and how objects move through time, transformation governs how an object’s properties shift from one state to another.
Every animation includes at least one transformation. An object might move across the screen, scale up as it enters, fade in from transparent, or rotate into position. The combination of transformations applied to an object determines its overall visual character.
Choosing the right transformation
Every transformation tells a story about where an object came from and where it’s going. A new screen entering as part of an onboarding sequence should move in the direction the flow is going. A notification should drop in from the top of the screen. An overlay that doesn't enter from a specific direction should fade into view. When the transformation matches the spatial context, the motion feels inevitable. When it doesn’t, the motion feels strange.
Most animations combine more than one transformation, and that’s where the object’s story comes together or falls apart. A confirmation screen that slides up and fades in simultaneously feels grounded because both properties support the same story. Compound transformations create richer motion than a single transformation alone, but only when every property change pulls in the same direction.
The most common mistake is adding a transformation that doesn’t contribute to the narrative. A bottom sheet rising into view while rotating creates a contradiction. The two transformations pull against each other, and the motion feels confused. Every property in a compound transformation should earn its place. If you can't articulate what a transformation contributes to the story, consider removing it.
