Who can use this feature
Organization and Enterprise plans
Your organization may require admin approval before an app can access its Figma resources. If an app hasn’t been approved, you can submit a request when you try to connect it.
This includes MCP clients, such as Cursor and Claude Code, and other apps that connect to your Figma account.
Note: This feature is rolling out gradually starting November 17, 2026. If you don't see it in your account yet, it should appear in the next few days.
Request approval for an app
Start from the app you want to connect and follow its instructions to connect your Figma account. If your organization requires approval, Figma displays a message identifying the app and explaining that approval is needed.
To submit a request:
- Enter a reason for your request, if you want to provide more context.
- Click Request access.
Your request goes to your organization’s admins for review.
App approval applies to your organization’s resources. If you work across multiple organizations, an app may be approved in one organization but require approval in another.
Once your app is approved, you will receive an email and notification. Approval makes the app available for your organization, but you still need to authorize it to connect to your account.
Request additional permissions for an approved app
An app may need more permissions after your organization approves it. For example, an app that previously read file content might add the ability to create comments.
If you try to connect with permissions your organization hasn’t approved, Figma displays a message explaining which permissions need approval.
To request additional permissions:
Your admin reviews the additional permissions. You receive a notification when they approve or decline the request.
If your request is denied
You receive an email and an in-Figma notification if an admin declines your request. If they provide a reason, it appears with the decision.
You can submit another request. Consider adding more information about your workflow or addressing the reason your admin provided.
If you can’t request access
Your organization may require approval without allowing members to submit requests. If you don’t see an option to request access, contact an organization admin about the app you want to use.
An admin may also change your organization’s policy or remove approval for an app you already use. If an existing connection loses access to organization resources, check with your admin.
