- Supported on any team or plan.
- Anyone who is logged in and has can edit access can create sections.
Organize your board with labeled sections to group related objects or guide workshop participants through activities. Sections let you:
- Cluster objects together without having to group them
- Contain objects that can be moved together around the board
- Hide sections of the board that can be revealed when needed
- Link collaborators to a specific section of the board
Create a section
There are two ways to create a section on your board.
Toolbar
- Click in the bottom toolbar or use the keyboard shortcut ⇧ Shift S.
- Click the location of the board where you’d like the section to go to create a square section, or click and drag to create a custom sized section.
You can also click and drag a section over the objects you want to add to it.
From selection
- Click and drag objects on the board you’d like to add to a section.
- Right-click the selection.
- Click Create section from the menu.
Learn more about selecting objects in FigJam →
Add template to section
Speed up your workflow and save time setting up a FigJam board with section templates for brainstorms, meetings, diagramming, and more.
To use section templates:
- Create a section.
- Click Templates next to the section title.
- Select a template from the list.
Learn more about using templates in FigJam →
Add objects to section
There are a few ways to add objects to a section:
- Move a section over an object
- Resize a section over an object
- Select and move an object into a section using your mouse or keyboard arrows
Press ⇧ Shift then click and drag to select multiple objects in a section.
Lock a section
Lock sections to prevent them and their contents from being moved or edited.
- Create or select a section.
- Click in the section's menu.
- Select whether you want to:
- Lock all to prevent the section and its contents from being moved or edited
- Lock background only to prevent the section from being moved or deleted while its content is still editable
Edit section title
To edit a section title:
- Create or select a section on the board.
- Click from the section’s toolbar.
- Enter a new name and press Return / Enter.
You can also double-click the section’s name to edit.
Remove title
- Double-click title or press .
- Delete text.
- Press Return / Enter.
To add a title back, press in the section's toolbar.
Hide section
Hiding sections comes in handy when you want to hide content without deleting it, or to expose content when needed during a presentation or group exercise.
Press to hide a section and to show it again.
Delete a section
To delete a section and its contents:
- Select the section.
- Press Delete/Backspace.
To delete a section without deleting its contents:
- Press CommandDelete/ControlBackspace.
Set section as thumbnail
Use a section as the thumbnail image for the file or a custom template.
- Select a section.
- Click Set as thumbnail.
