Use the theme settings you change the appearance of the Figma interface. Choose between light or dark themes, or let your system settings determine the theme.
Change the theme
You can change your theme from the main menu or from the Actions menu.
Theme settings are device-specific. If you're using a Figma account across multiple devices, theme settings from one device won't carry over to another. Changing your theme also won’t affect appearance settings for others, even if you’re viewing the same file.
When you create new files, Figma sets the background color to light or dark color depending on your current theme. While in light mode, newly created files default to a light-gray background color #F5F5F5
. While in dark mode, they’ll default to an off-black color #1E1E1E
Note: New pages determine their canvas color based on the current page’s canvas color, and don’t rely on your current theme. Learn more about changing the background color of the canvas.
Main menu
To change your theme from the Main menu:
- Open any file you have access to.
- Click Main menu.
- Go to Preferences > Theme.
- Select an option from the list of themes.
Actions menu
To change your theme from the Actions menu:
- Select the Actions menu in the toolbar or use the keyboard shortcut:
- Mac: ⌘ Command /
- Windows: Control /
- Type in search terms and select the theme you want to use
Use dark mode
Use light mode
Use system theme
Tip: Plugin developers can match their plugin UI to Figma’s light and dark modes. Learn more from Figma’s plugin developer docs.
