Locating text on a busy board can be a challenge. Find and replace lets you quickly navigate through text and make content updates as you go.
Using Figma? Check out our Find and replace text in Figma files article.
Find text
Use the Find option to quickly search your entire file for sticky notes, text strings, and section names.
- Open the search bar using the keyboard shortcut:
- Mac: Command + f
- Windows: Ctrl + f
- Enter the text you want to find. The search results automatically populate as you type.
- Click to add search filters and use and to move through the results.
- Click or press Esc to close the search bar.
Replace text
Requires edit access to the file.
Use the Replace option to quickly replace text.
- Click and select Replace.
- Search for the text you want to replace.
- Enter the replacement text in the Replace with field.
- Click Replace to replace the currently highlighted instance or click Replace all to replace all instances.
