Before you start
Who can use this feature
Professional, Education, Organization, Government, and Enterprise plans
In Figma, variables are stored values that represent design attributes or saved states. They can be string, number, color, or boolean value types.
You can set and modify the values of variables with prototyping actions—allowing you to create immersive prototypes that dynamically change based on user selection, using only a few simple frames and interactions. This means you can use prototype actions to:
- Update text content with string variables
- Change object dimensions, corner radius, or auto layout properties with number variables
- Toggle layer visibility with boolean variables
To begin using variables in prototypes, set up your variables, then use the Set variable action to change or modify your variable values.
Once you’ve got the hang of using variables and prototypes together, try some more advanced features to extend their power even further:
- Expressions: Manipulate variables with basic operations, allowing you to build more advanced prototypes with flexible values
- Multiple actions and conditionals: Use if/else statements to check if a condition is met before performing actions, and stack an unlimited number of actions on a single trigger
Learn more about variables in Figma.
Try it out
Want to get even more practice? Check out the advanced prototyping playground file.
Looking for more examples of how you can use variables in prototypes? Check out some more advanced prototyping examples.
Set up your variables
Before you can prototype with variables, you need to:
- Create your variables: Learn how to create and organize variable collections.
- Apply variables: Learn how to apply variables to text content, object dimensions, layer visibility, and more.
Set variable values
Once you’ve created and applied variables throughout your design, you can start using them with prototypes.
Each prototype interaction has a trigger (what causes the prototype to advance forward) and one or more multiple actions (what happens as a result of the trigger).
The Set variable action allows you to set or modify the value of a variable as a result of a prototype trigger.
To use the Set variable action on a prototype interaction:
- Create a prototype interaction.
- Navigate to the Interaction modal and select a trigger from the dropdown menu.
- From the Action dropdown menu, select Set variable.
- From the Target dropdown menu, select the variable you want to set a new value for.
- In the Value field, enter in a new value for the variable. The new value type must match the variable type you’re changing. For example, if you selected a number variable, the new value must also be a number.
- String values: Enter any text string literal (contained in quotations), or select any string variable from the selection panel
- Number values: Enter any number value, or select any number variable from the selection panel
Boolean values: Enter
trueorfalse, or select any boolean variable from the selection panel - Color values: Enter any hex code, or select a hex code from the color picker
- Play your prototype to test the interaction.
Note:
Do your variables have multiple modes? Learn more about setting variable values to specific mode values.
Tip:
Use expressions to manipulate variables with operations. For example, you can perform basic math on number variables, combine multiple string variables together, or use boolean expressions.
Try it out
Let’s create a collection of variables titled “Shapes”. This collection will include one string variable that represents the name of the shape.
- Deselect all items on the canvas, then find the Local variables section in the right sidebar and click Open variables.
- Click Create variable, and select String.
- In the Name column, enter “shapeName”.
- In the Value column, enter “circle”.
Now, you can apply the shapeName variable to your design. For this example, we’ve created a simple design that includes a frame with two shapes (a circle and a square) and two text layers. We want to bind the shapeName variable to the bottom text layer so that it changes based on the selected shape.
- Recreate the design pictured below. Add an ellipse object, a rectangle object, and two text layers to a frame. Enter “You picked:” as the content of the first text layer.
- Click to select the bottom text layer on your frame.
- From the Design tab in the right sidebar, find the Text section and click Apply variable.
- Select the
shapeNamevariable from the variable selection panel to apply it to the text content.
Now, let’s add an interaction with a Set variable action.
- Select the ellipse object.
- From the right sidebar, switch to the Prototype tab. In in Interactions section, click the plus sign to add a new interaction.
- In the Interaction modal, create an interaction with an On tap/On click trigger and the Set variable action.
- Select the
shapeNamevariable from the Target dropdown menu. In the Value field, set the new value to “circle”. - Repeat steps 1-4 for the rectangle object. This time, set the
shapeNamevariable to “square”.
Now, you’re ready to play your prototype to test it out. When you click each shape object, the text layer will automatically update based on the new variable value.
Prototype with variables and components
Once you’ve learned the basics, you can start using variables and components together in your prototypes.
Apply variables to components to automatically update your component when you change the value of a variable in a prototype. Any change in variable value also updates any other elements bound to that same variable.
The value of a variable can be changed by:
- Using the Set variable action
- Using the Change to action in an interactive component
- Using the Set variable mode action
Example
An interactive button component set has a default and a hover state. The component uses the Change to action, so that when you hover over the default variant, it switches to the hover variant (and vice versa).
A boolean hoverState variable is applied to both an instance of the variant and the visibility of a separate, overlay layer.
When you hover over the default variant in your prototype:
- The instance updates to the
hovervariant - The
hoverStateboolean variable updates from false to true - The image layer is made visible
Want to practice with a similar example? Check out the “Try it out” section below.
The location where you apply the variable determines the scope of changes in the prototype.
| Apply variable to: | When prototyping: |
| Variant properties of component instances | Change the value of the variable to update the variant of the instance. |
| Component properties | Change the value of the variable to update all instances of the component. |
Learn more about applying variables to component and variant properties.
Try it out: Example 1
- Create an interactive component set.
- Create a button component that has a “clicked” variant property with “true” and “false” values.
- Add a prototype interaction on the “false” variant, using the On click trigger and the Change to action. Now, when the false variant is clicked, it will switch to the true variant.
- Place an instance of a variant from the interactive component set in a frame.
- Add the false variant to a frame.
- Assign a variable to the interactive component instance. The value of the variable must match a variant property value.
- Create a boolean
circleVisibilityvariable with a default false value. - Select the instance of the button.
- From the right sidebar, hover over the clicked variant property.
- Select Apply variable.
circleVisibilityvariable to bind to the property.
- Create a boolean
- Assign the same variable to another layer in your design.
- Add an ellipse object to the frame.
- From the Appearance section of the right sidebar, right-click the Hide icon.
- Select the
circleVisibilityvariable to apply the boolean variable to the visibility of the ellipse layer.
- Play your prototype to test the interaction. When the interaction is triggered and the component is changed, the value of the variable also changes. This means that if you have that same variable bound to any other values, those will also update.
Try it out: Example 2
- Create a component set with at least two variants.
- Create a component set that has a “shape” variant property with “circle” and “square” values.
- Place an instance of a variant on a frame.
- Assign a variable to the instance. The value of the variable must match a variant property value.
- Create a
shapeTypestring variable with a default “circle” value. - Click on the instance to select it.
- From the right sidebar, hover to the right of a variant property and click Assign variable.
- Select the variable you’d like to bind to the property.
- Create a
- Create an interaction on any object within the frame that uses the Set variable action. Change the value of the variable to match the value of the unused variant property.
- Add a prototype interaction on an object, using the On click/On tap trigger and the Set variable action. Set the
shapeTypevariable value to “square”.
- Play your prototype to test the interaction. When the interaction is triggered and the variable is changed, the variant also updates.
