Before you start
Who can use this feature
Available on any paid plan.
Anyone with can edit
access to a file can create prototypes.
Anyone with can view
or can view prototypes only
access to a file can view prototypes.
As your prototypes increase in depth and complexity, you can use multiple actions and conditionals to handle multiple or different outcomes within the same interaction.
- Multiple actions: Stack an unlimited number of actions on the same trigger
- Conditionals: Check if a condition is met before performing an action by using an if/else conditional statement
New to variables? Learn more here:
Want to get more hands-on practice?
Check out the advanced prototyping playground file →
Looking for more examples of how you can use variables in prototypes? Check out some more advanced prototyping examples →
Note: This video explains prototyping using Figma's old interface. For examples of the new interface, see the images in this article.
Multiple actions
Every prototype interaction has a trigger and one or more actions. A trigger is what causes the interaction to begin, and an action is the response.
Multiple actions allow you to add an unlimited number of actions on one trigger.
- Create a prototype interaction.
- To add an additional action, click Add action.
- From the Interaction panel, select any action from the Action dropdown menu.
Tip: Collapse or expand details of each action by clicking the chevron to the left of the action name.
Reorder actions
Actions run in the order in which they’re listed, from top to bottom.
To reorder actions:
- Open an Interactions panel.
- Click to the left of the action and drag to change its order.
Tip: You can drag and drop any action into a Conditional action.
Changing the order of actions can change the outcome of a prototype.
For example, two sample prototype actions are listed below. For this example, the starting value of numberVar
is 1
In the first action, the number variable is set to a value of 2
. This means the conditional statement (if numberVar == 2
) is evaluated to be true, so the action (Navigate to Frame 2) executes.
Now, switch the order of the actions:
In the first action, the conditional statement (if numberVar == 2
) is evaluated to be false, so the action does not execute, and the prototype stays on the current frame. Then, the value of numberVar
is changed to 2
Animation order
Prototype animations can be used to create smooth transitions between pages and define the behavior for actions like Navigate to, Scroll to, Open overlay, and more.
If you have multiple animations on a trigger, they run sequentially.
Conditionals
In prototyping, a conditional is a rule that defines if an action should trigger. Conditionals are written with if/else logic.
For example, consider building a checkout flow. If the cart total is higher than a certain amount, the user receives free shipping. If not, or else, the user sees the full shipping price.
In Figma, you can use the Conditional prototype action to build prototypes with conditional logic.
- From the Interaction panel, select any trigger from the dropdown menu.
- From the Actions dropdown menu, select Conditional.
- Complete the If condition:
- In the If field, write a boolean expression to represent the condition that must be met.
- Select an action (or multiple actions) from the dropdown menu. These actions will be triggered if the If statement is met.
- Complete the Else condition:
- Select an action (or multiple actions) from the dropdown menu. These actions will be triggered if the If statement is not met. Alternatively, leave the Else action blank.
Only conditionals written with supported operations and format will work. Invalid conditional statements will be outlined in red.
Evaluate conditional statements
Conditional statements are identical to boolean expressions—the statement is evaluated to have a true or false value. If the value of the statement is true, the if action is triggered. If the value of the statement is false, the else action is triggered.
Learn more about how to format and evaluate boolean expressions →
