Sticky notes in FigJam
Stickies are the virtual equivalent to the sticky notes we all know and love. They're the core for any FigJam board, along with shapes and connectors.
Use stickies for:
- Brainstorms and pitch sessions
- Retrospectives
- Kanban style to-do lists or project management
- Card sorting exercise
- Anything you put your mind to that involves text in a colorful sticky note!
Stickies can only contain text.
Create a sticky note
There are a few ways to create a sticky note, from either the toolbar, existing stickies on the board, or CSV files.
From the toolbar and shortcuts
- Click the stack of stickies in the toolbar.
- Hover the sticky preview over the board to pick a spot.
- Click again to drop the sticky.
You can also drag and drop a sticky from the toolbar onto the board.
Once your sticky is on the board, you can immediately start typing to add text.
The color of your stickies is randomly selected when you open a jam file, and can be changed using the settings bar when you select a sticky from the board. Changing a sticky's color on the board will change the color of your stack in the toolbar for new stickies.
Keyboard shortcut
Use the keyboard shortcut:
- Press S.
- Click to drop the sticky.
Quick actions bar
Open the quick actions bar using:
Mac: ⌘ Command /
Windows: Control /
Type sticky, then hit Return or Enter.
From existing stickies
Quick create
Select an existing sticky note.
Mac: ⌘ Command Return
Windows: Control Enter
A new, blank sticky note will appear next to the original one with text field active.
Learn more about quick create →
Duplicate
To duplicate a sticky:
Select an existing sticky, then use the keyboard shortcut:
Mac: ⌘ Command D
Windows: Control D
Or, press Alt then click and drag from an existing sticky.
In either case, the original sticky is duplicated along with any text inside it.
From CSV files
FigJam's CSV import function lets you import data from any CSV file. Each piece of data, or cell, will be imported as its own sticky.
Learn more about importing spreadsheet data to FigJam →
Add connectors
Add connectors between stickies to diagram flows or create paths for others to follow.
- Click in the toolbar.
- Select between an elbow or straight connector. You can also use the keyboard shortcuts ⇧ Shift C to create an elbow connector, and L for a straight connector.
- Click and drag your cursor between the objects you want to connect.
Once created, you can click and drag a connector's start or end point to another object, or another side of the same object.
Learn more about creating connectors →
Add your name to a sticky
Your stickies automatically include your name at the bottom. This is great for group collaboration where other team members are adding their own stickies to the board. By default, the name on your stickies is taken from your account settings.
To add or remove your name to a sticky:
- Add a sticky to the board.
To remove your name, click again.
If you clear the text in another person's sticky note, your name is added to the sticky.
Edit stickies
You can edit a sticky's color, text, and the text's formatting. Edits can also be made in bulk to a group of selected stickies.
To edit a sticky:
- Select one or more stickies by:
- Clicking on a single sticky
- Clicking and dragging your cursor over multiple stickies
- Or, clicking on multiple stickies while pressing Shift
- Edit the text fields or use the toolbar to edit color and text formatting.
Learn more about selecting objects in FigJam →
Format text
You can change the text's formatting using the sticky's toolbar when it's selected. From here, you can change the text's size, weight, create lists, and more.
Learn more about formating text in FigJam →
Color
To edit a sticky's color:
- Select the sticky.
- Click the color picker in the toolbar.
- Select a new color.
You can change sticky colors in bulk by selecting mutliple stickies. Learn more about using colors FigJam →
When you select a group of stickies with more than two colors, the color picker will only show up to two of the selected colors.
Size
Stickies come in two shapes: a square and rectangle, like an index card-sized sticky. They change in size vertically depending on its text contents and can be made wider by dragging a side edge. You can also drag a corner to scale their size equally. Shapes with text can be scaled to a different size regardless of its content.
Learn more about resizing objects FigJam →
Delete a sticky
To delete a sticky from your board:
- Press Delete.
