Sort and summarize stickies with FigJam AI
Note: Figma’s AI features are currently free while in beta, but usage limits may apply. When made generally available, Figma AI will become a paid feature. We’ll update you on pricing before that happens.
Before you start
Who can use this feature
Available in FigJam
Available on paid plans
Requires can edit file access
FigJam is the perfect place for hosting collaborative exercises like brainstorms, design critiques, and retrospectives. As a result, you may be left with a load of sticky notes to sift through and categorize before you can create alignment and outline next steps. This is where FigJam AI steps in to help.
Use FigJam AI to:
- Sort a selection of stickies by theme
- Summarize a selection of stickies
Sorting and summarizing stickies with FigJam AI should only be used as a step in the larger process of sorting and summarizing your work, so your own magic touch may be needed to get the job done.
Sort sticky notes
To sort stickies:
- Select the stickies on your board.
- Click Organize in the selection’s toolbar > Sort stickies.
- Sort stickies by Topic, Color, Author, Stamp count, or Stamp type.
FigJam AI will create a copy of the selected stickies and categorize them in a new section. From here, you can manually adjust sorting as needed.
Summarize sticky notes
To summarize stickies:
- Select two or more stickies on your board.
- Click the Organize in the selection’s toolbar.
- Click Summarize.
FigJam AI will create a new object on the board with a written summary of the stickies. You can Copy the text to paste and edit in a new shape or sticky, and click Link to copy a link of the summary to your clipboard.
It's currently not possible to edit summaries made with FigJam AI, but you can Copy the text to a new shape or sticky and edit.
