Add tables to your slides to present information in an organized and structured manner. You can create tables from scratch or import CSV files as tables directly into Figma Slides.
Add a new table
To add a new table:
- Click Assets in the toolbar.
- Select Table.
- Click and drag your cursor to create a table with the number of rows and columns you need.
Once added, you can double-click inside a table cell to start typing.
Import content from other spreadsheet tools
You can bring content from other spreadsheet tools, such as Google Sheets, into Figma Slides. You can also copy FigJam tables and paste them into Figma Slides.
Note: Tables have a 500 cell limit. If the content you’re importing contains more than 500 cells, you’ll need to import it into multiple tables.
Copy and paste content
- Copy the cells from your spreadsheet.
- Click on an empty spot in a slide to deselect any objects.
- Paste the spreadsheet content on to the slide.
Figma Slides will automatically add a new table with the correct number of rows and columns.
Import a CSV file
You can drag and drop CSV files from your computer into a Figma Slides deck to import the content as a table.
Edit and format tables
You can adjust the styling of an individual cell, row, column, or the entire table.
Select the content you want to format and use the settings in the right sidebar to do the following:
- Change the background fill
- Adjust the font size or typeface
- Add font styling
- Change the text alignment
- Create links
Resize tables, rows, or columns
Resize an entire table
To resize a table:
- Select the table.
- Use the handles to resize the table.
Resize a row or column
- Hover your cursor over the border of the row or column you want to resize.
- Click and drag your cursor to adjust the height or width of the row or column.
Add rows or columns
To add a row or column at the end or bottom of the table:
- Select the table and hover your cursor over the last column or row.
- Click the blue bar that appears at the edge of the table.
To add a row or column in the middle of the table, select the blue plus that appears.
Note: If you don’t see the blue plus, you may need to zoom in.
Move rows or columns
Select the row or column you’d like to move and use the blue handle to move it inside the table.
Delete rows or columns
To delete a row or column, select it and press Delete.
