Figma Sites was released in open beta at Config 2025. Learn more about what’s included in the beta.
Who can use this feature
Starter, Professional, Education (not K-12), Organization, and Enterprise plans
You can make your site more accessible by applying the correct HTML tags and accessibility properties to each element in your design.
This improves usability for people who rely on screen readers or keyboard navigation. Semantic HTML also clarifies your site’s structure and can boost search engine optimization (SEO).
Tips for making your site more accessible
- Add alt text to images that need description, or mark it as decorative. Keep alt text concise and functional—focus on purpose, not appearance.
- Set the correct HTML tag. Use a role only when no semantic tag fits.
- Add labels when visible text is missing or unclear.
- Mark purely decorative elements as hidden.
- Use the color contrast tool in the color picker to improve readability.
Note: These guidelines are for informational purposes only. Please consult with a lawyer to ensure you understand your legal obligations with respect to accessibility. Do not rely on these guidelines or Figma Sites to make sure you are in compliance with the law.
Set the HTML tags for layers
The Layers panel shows each layer’s assigned HTML. By default, most layers will use a div tag. Figma also automatically applies these tags:
- Text layers use the
ptag. - Frames and rectangles with a media fill use
imgorvideo. - Layers with a link applied use an
atag. - Layers with on click interactions use the
buttontag.
To update an element’s tag:
- Select one or more layers on the canvas.
- In the right sidebar, navigate to the Accessibility section and choose a new tag.
Tip: You can also right-click a layer on the canvas or in the Layers panel and select HTML tag from the contextual menu.
Note: If you can’t see the HTML tags listed in the Layers panel, click Zoom/view options at the top of the right sidebar and enable Show HTML tags on layers.
Set accessibility landmarks
Landmarks are specific HTML tags that help people using assistive technologies navigate a site quickly and easily.
Tip: Learn more about landmarks by visiting the ARIA Authoring Practices Guide.
Landmark |
HTML Tag |
What it means |
Container |
div |
A general container for grouping elements, often used for styling and layout. |
Section |
section |
A segment of a webpage that groups related content, usually with a heading. |
Article |
article |
A self-contained piece of content—like a blog post, press release, or help center article—that can stand on its own. |
Aside |
aside |
Contains content related to the main content, like sidebars or extra information. |
Navigation |
nav |
A section with navigation links. |
Header |
header |
The top of a section or page, usually with a title or navigation links. |
Footer |
footer |
The bottom part of a page or section, usually with information like copyright notices or links. |
Main Content |
main |
The primary content area of a page; usually excludes headers and footers. |
Button |
button |
Represents a clickable element that can trigger an action or event, such as submitting a form or opening a dialog. |
Media container |
figure |
Used to group media content—like images, illustrations, code snippets, videos—with an optional |
Ordered list |
ol |
Represents a list of items in a specific sequence or order, typically displayed with numbers. |
Unordered list |
ul |
Represents a list of items without inherent order, usually displayed with bullets. |
Note: By default, a div provides no meaning to assistive technologies like screen readers. Adding attributes such as a label alone often has no effect unless you also apply a role.
For example:
<button aria-label="Close">works because<button>already has a semantic role. -
<div aria-label="Close">does not work unless you addrole="button".
Set heading tags for text layers
Use heading tags define structure. Screen readers use these tags to help users navigate sections quickly.
h1marks the main heading of the page. Avoid using multipleh1tags on one page. -
h2toh6create subheadings that show content hierarchy.
Tip: Avoid skipping heading levels. Start your page with an h1 tag, followed by h2, and so on. This helps enforce a proper hierarchy and structure.
Set list tags to group related items
Use list tags to define groups or collections of related layers. Screen readers use these tags to help users understand relationships between items, improving readability and navigation.
ulmarks an unordered list for related but unordered content. -
olmarks an ordered list when sequencing or priority matters. -
lirepresents an item in a list; they are automatically applied to any layers nested within theuloroltags.
Using bullets in text automatically applies these tags accordingly.
Configure accessibility properties
You can add properties that give assistive technologies more context about each element. Options include:
- Set alt text for images and video
- Add a label
- Hide decorative content
- Identify the current item
- Add a role
To configure accessibility properties for elements on your site:
- Select the element you’d like to adjust.
- Click Add accessibility settings in the Accessibility section of the right sidebar.
- Choose from the available options. You can find more information about each property type below.
Images in your site are automatically assigned the img tag, while elements with a video fill are assigned the video tag.
Select Alt text to write a brief description of the image or video that provides context to users who cannot see it, such as those using screen readers.
You can also mark the element as decorative so they’re ignored by screen readers. Use this when the element provides no functional purpose, or is already described by visible text on the screen. This is the same as making it hidden.
This maps to the alt attribute.
Tip: Looking for more guidance on how to write effective alt text? Check out Alt text: What to write from Nielsen Norman Group.
Add a label
Labels provide names for elements without clear visible text. For example, an icon-only button— like a magnifying glass that opens a search box—can be labelled search.
This maps to the aria-label attribute.
Tip: If the selected element already has a readable label in your design, you usually don’t need to add an accessibility label.
Mark decorative elements as Hidden so screen readers skip them. For example, you might hide background shapes or ornamental illustrations.
This maps to the aria-hidden attribute.
Tip: Marking an element as Hidden means that any other accessibility settings are ignored.
Use Current item to mark which item in a set is active right now. This helps screen readers announce the correct context.
This maps to the aria-current attribute.
Value |
What it means |
Example use |
page |
The link to the current page within a set of navigation links. |
A nav menu item for the page the user is currently on. |
step |
The current step in a process or progress tracker. |
Step two of a multi-step checkout flow. |
location |
The current location within a physical or virtual map interface. |
The active marker on a store locator map. |
date |
The currently selected date in a calendar or date picker. |
Showing the currently selected day in a calendar widget. |
time |
The currently selected time in a time picker. |
Marking the active time slot in a booking interface. |
true |
A generic indicator that the element is the current item in its context. |
Highlighting the active tab in a tabbed interface. |
false |
Default state; the element is not the current item. |
All other inactive links or options. You generally don’t need to set these manually; it’s the same as not applying |
Add a role
Roles describe how an element works for assistive technologies. Use semantic HTML tags—like button or nav—wherever possible, and a role in situations like:
This maps to the role attribute.
- You’re using a generic element like a
divbut need to convey meaning. - You’ve customized an element’s behavior and need to reflect that behavior programmatically. For example, treating a tabbed container as a
tablistwithtabchildren. - You want to provide context beyond the default HTML tag. For example, marking a section as a
formto highlight its purpose.
Roles don’t affect how elements look or behave visually, but they redefine an element’s semantic meaning. This change gives assistive technologies the context they need to present robust, meaningful information to users.
They are grouped into categories such as Regions, Document, and Interactive—each with specific roles for navigation, structure, or user controls.
Regions
These roles define major sections of a page, making it easier for screen readers to offer quick navigation.
Role |
What it means |
Example use |
banner |
A site-wide header, usually at the top of the page. |
The global header with logo and site-wide navigation. |
complementary |
A supporting section of content. |
A sidebar with related links or ads. |
contentinfo |
Info about the parent document, often a footer. |
The bottom of a page with copyright text. |
form |
A region containing form elements. |
A login or checkout form. |
main |
The primary content of the page. |
The main article content in a blog. |
navigation |
A region with navigation links. |
A site-wide nav menu or secondary navigation. |
region |
A labeled, significant area of the page. |
A labeled panel in a dashboard. |
search |
A region for search functionality. |
A search bar at the top of the page. |
Document
These roles describe the structure of page content. They help communicate the hierarchy and semantics of your content.
Role |
What it means |
Example use |
article |
A self-contained composition. |
A blog post or press release. |
blockquote |
A section quoted from another source. |
Pull quotes in an article. |
caption |
A description or title for media. |
Caption for a figure or table. |
cell |
A single cell in a table. |
A table cell with data. |
code |
Programmatic text. |
Displaying a snippet of code. |
definition |
The definition of a term. |
Glossary entries. |
directory |
A list of references or navigation. |
A table of contents. |
document |
Represents an entire embedded document. |
Embedding a PDF viewer. |
emphasis |
Text with emphasized meaning. |
Highlighted words in a paragraph. |
feed |
A dynamic list of articles or updates. |
A news feed or activity stream. |
figure |
Independent content with a caption. |
An image with a caption. |
group |
A collection of items that form a logical set. |
A set of related form fields. |
heading |
A heading in the document outline. |
Section headings. |
img |
An image. |
Decorative or meaningful images. |
list |
A group of list items. |
A bulleted or numbered list. |
listitem |
An item in a list. |
A single list entry. |
math |
Mathematical content. |
A complex equation. |
note |
Supporting information. |
Side notes or annotations. |
paragraph |
A block of text. |
A standard paragraph. |
presentation |
Layout-only content. |
A decorative container. |
row |
A row of cells in a table. |
Table row in a spreadsheet. |
rowgroup |
A grouping of table rows. |
A tbody element. |
rowheader |
A header cell for a row. |
Row titles in a table. |
separator |
A divider between sections. |
A horizontal rule. |
strong |
Strong importance. |
Bold text for emphasis. |
subscript |
Subscript text. |
Chemical formulas. |
superscript |
Superscript text. |
Footnote references. |
table |
A table of tabular data. |
Product pricing table. |
term |
A word or phrase being defined. |
Dictionary entry. |
time |
A time value or timestamp. |
Publication date. |
toolbar |
A container of controls. |
Text editor toolbar. |
tooltip |
A brief label that appears on hover or focus. |
Tooltip for an icon button. |
Interactive
These roles define user interface controls. They communicate what users can do with them and how they behave.
Role |
What it means |
Example use |
button |
A clickable button. |
Submit button in a form. |
checkbox |
A checkbox that can be checked or unchecked. |
Newsletter subscription checkbox. |
gridcell |
A cell in a grid. |
Data cell in a spreadsheet app. |
link |
A hyperlink to another page or resource. |
A navigation link. |
menuitem |
An option inside a menu. |
“Save As” in a dropdown menu. |
menuitemcheckbox |
A menu item like a checkbox. |
Toggle “Show Line Numbers”. |
menuitemradio |
A menu item like a radio button. |
Choose theme: Light or Dark. |
option |
An option in a listbox. |
Dropdown options. |
progressbar |
Shows task progress. |
Upload progress indicator. |
radio |
A single radio button. |
Select payment method. |
scrollbar |
A scrollbar for scrolling content. |
Custom scrollable area. |
searchbox |
A search input field. |
Search field in a header. |
slider |
A slider for selecting values. |
Volume control slider. |
spinbutton |
A numeric input with controls. |
Quantity selector in a cart. |
switch |
A toggle switch. |
Dark mode toggle. |
tab |
A tab in a tabbed interface. |
“Details” vs “Reviews” tab. |
tabpanel |
The panel linked to a tab. |
The “Reviews” content panel. |
textbox |
A text entry field. |
Comment box. |
treeitem |
An item in a hierarchical tree. |
A folder in a file tree. |
combobox |
Combined input box and dropdown. |
Searchable dropdown. |
grid |
A grid layout with rows and cells. |
Spreadsheet grid. |
listbox |
A list of options. |
Dropdown list of countries. |
menu |
A container of menu items. |
File menu in an app. |
menubar |
A horizontal set of menu items. |
Top navigation in a desktop app. |
radiogroup |
A group of radio buttons. |
Shipping method options. |
tablist |
A list of tabs. |
Tabs above a panel area. |
tree |
A tree widget for hierarchical data. |
File explorer tree. |
treegrid |
A grid with expandable rows. |
Interactive data grid with nested rows. |
alert |
A high-priority message. |
Error alert banner. |
log |
A region that logs messages dynamically. |
Chat log panel. |
marquee |
A scrolling region of text. |
News ticker. |
status |
A region that presents status messages. |
Connection status indicator. |
timer |
A time-based status region. |
Countdown timer. |
alertdialog |
A dialog that interrupts the user. |
“Are you sure?” confirmation. |
dialog |
A generic dialog box. |
Settings modal window. |
comment |
A region that contains comments. |
Comment thread. |
suggestion |
A proposed change. |
Suggested edits in a doc. |
