Who can use this feature
Starter, Professional, Education (not K-12), Organization, and Enterprise plans
Figma Sites was released in open beta at Config 2025. Learn more about what’s included in the beta.
The homepage is the first page that loads when someone visits your published site. If you need to change which page is set as the homepage, follow these steps:
- In the Webpages section of the left sidebar, find the webpage you want to set as the homepage.
- Right-click the name of the webpage, then select Set as homepage.
If your site is published, you’ll need to republish it for these changes to take effect.
Tip: You can also right-click the webpage on the canvas and select Set as homepage from the menu that appears.
Note: Both the old homepage and the new homepage will keep their existing metadata in Website settings. If needed, you can always update these fields to reflect the change.
