Figma Sites was released in open beta at Config 2025. Learn more about what’s included in the beta.
Who can use this feature
Starter, Professional, Education (not K-12), Organization, and Enterprise plans
Previewing your site helps you experience it as your users do. It’s a great way to quickly check animations, interactions, and responsiveness—without needing to publish first.
There are two ways to preview a webpage or a site:
Access the inline preview
Use the inline preview to view your site directly on the canvas alongside your designs. You can keep the inline preview window open while making design changes, letting you quickly go back and forth to see how your changes look when rendered in a browser environment.
Tip: When you click another webpage on the canvas, the preview straight jumps to that webpage.
To open the inline preview, click the down arrow next to the Preview button at the top of the right sidebar, then select Inline preview. You can also use the keyboard shortcut: Shift Space.
Here are a few ways you can control your previewing experience:
- Navigation controls: Click the Back and Forward buttons to mimic the corresponding browser buttons.
- Automatically resize: Snap the preview to desktop, tablet, or mobile breakpoints.
- Manually resize: Click and drag the edge of the window. Hold Shift to scale it proportionally. You can also enter specific width and height values.
- Change the scale: Enter a scale percentage to increase or decrease the size of the window. This is a good option when you want to keep the preview window open while freeing up more space to work on the canvas.
- Reload: Click Reload to see the most recent changes.
- Open in full-screen: Click Open full preview to switch to a full-size preview window.
Access the full-screen preview
Use the full-screen preview to take over the window and maximize the space you have for testing your site. To open the full-screen preview, click Preview on any webpage, or next to the Share button at the top of the right sidebar. You can also use the following keyboard shortcuts:
- Mac: ⌘ Command ⌥ Option Return
- Windows: Control Alt Enter
Here are a few ways to control the preview:
- Close the preview: Click Close to exit the full-screen preview.
- Switch pages: Click the webpage slug to jump between pages.
- Manually resize: Enter specific width and height values, or drag the handles at the edge of the preview window. Hold Shift while dragging to resize the window proportionally.
- Scale: Enter a scale percentage to increase or decrease the relative size of the preview.
- Reload: Click Reload preview to see the most recent changes.
- Restart preview: Click Restart preview to return the preview to it’s original state. This is helpful if you’re testing links on a particular page and want to return to the place where you started when you first opened the preview window. Restart preview won’t work if you navigate between webpages by clicking the webpage slug.
Troubleshoot issues when previewing
The webpage on the canvas isn’t showing the same thing as the preview window
You may notice some inconsistencies between how an object appears on the canvas, in the preview window, and on the published site. The canvas serves as a design workspace, while the preview reflects how the design will function in an actual browser.
Some elements—like animations, interactions, code layers or embeds—may not render accurately on the canvas. In the preview window, everything renders as if in a browser, including fonts, flexbox layouts, and embedded content.
While we try and render everything as close to your design as possible, some things may look different due to different browser technologies.
Here are some examples which of where you might find inconsistencies between the canvas and the browser:
- Text decorations like underlines and strikethroughs may appear differently than designed.
- Mixed line heights may show up inconsistently across browsers. To fix, set to a single value.
- Dashes may appear differently than designed.
- Smart animate may not work as expected with vector properties (such as masks, strokes, and fills) or effects.
- Shadows on rotated layers may appear differently than designed.
- Rotations that include groups or objects that change in size can’t use smart animate.
Tip: You can check if there are any issues preventing your site from rendering correctly by clicking Review issues at the bottom left corner of the file.
An interaction or animation isn’t working as expected
- Review interaction settings: Check the interaction settings in the Interaction panel in the right sidebar. Verify that the settings for your interaction or animation are correctly configured. Make sure triggers and targets are properly assigned, and the values on each interaction property are correct. If an interaction has the icon, it is not supported in Figma Sites.
- Check for overlapping elements: Check the canvas and the Layers panel in the left sidebar to see if there are elements on top of your interactive element that are preventing it from working as expected.
The font size looks too big or too small in the preview window
- Check for breakpoint-specific text styles: If the font is appearing too big or too small in a specific breakpoint, it might be the case that you’re using a font style that is specifically customized for different breakpoints.
