Before you start
Who can use this feature
Figma Make is available for Full seats on paid plans.
You can try Figma Make on other seats and plans.
To help Figma Make create a functional prototype or web app that better meets your needs and expectations, you can provide guidelines in the Guidelines.md file. This includes instructions for how you want Figma Make to behave in terms of coding and personality, and how to use things like style context.
Add guidelines
To open the guidelines file:
- At the top of Figma Make, click Code.
- In the file explorer at the left side of the code editor, click guidelines, and then Guidelines.md.
Instructions, best practices, and examples of how to use the guidelines file are included in the file itself. For convenience, the content of the file is available in the following section.
Content of the Guidelines.md file
System Guidelines
Use this file to provide the AI with rules and guidelines you want it to follow.
This template outlines a few examples of things you can add. You can add your own sections and format it to suit your needs
TIP: More context isn't always better. It can confuse the LLM. Try and add the most important rules you need
# General guidelines
Any general rules you want the AI to follow.
For example:
* Only use absolute positioning when necessary. Opt for responsive and well structured layouts that use flexbox and grid by default
* Refactor code as you go to keep code clean
* Keep file sizes small and put helper functions and components in their own files.
# Design system guidelines
Rules for how the AI should make generations look like your company's design system
Additionally, if you select a design system to use in the prompt box, you can reference your design system's components, styles, and variables.
For example:
* Use a base font-size of 14px
* Date formats should always be in the format “Jun 10”
* The bottom toolbar should only ever have a maximum of 4 items
* Never use the floating action button with the bottom toolbar
* Chips should always come in sets of 3 or more
* Don't use a dropdown if there are 2 or fewer options
You can also create sub sections and add more specific details
For example:
## Button
The Button component is a fundamental interactive element in our design system, designed to trigger actions or navigate
users through the application. It provides visual feedback and clear affordances to enhance user experience.
### Usage
Buttons should be used for important actions that users need to take, such as form submissions, confirming choices,
or initiating processes. They communicate interactivity and should have clear, action-oriented labels.
### Variants
* Primary Button
* Purpose : Used for the main action in a section or page
* Visual Style : Bold, filled with the primary brand color
* Usage : One primary button per section to guide users toward the most important action
* Secondary Button
* Purpose : Used for alternative or supporting actions
* Visual Style : Outlined with the primary color, transparent background
* Usage : Can appear alongside a primary button for less important actions
* Tertiary Button
* Purpose : Used for the least important actions
* Visual Style : Text-only with no border, using primary color
* Usage : For actions that should be available but not emphasized
Guidelines for Make kits
Make kits are a way of sharing library styles and design system packages with your teammates. A critical part of Make kits are guidelines, which allow Figma Make to use your Make kit to create high quality, reliable output.
Because guidelines for Make kits require a specialized approach based on how you're assembling your Make kit, we cover best practices in two articles:
- For library styles, see Guidelines for library styles in Bring style context from a Figma Design library to Make kits.
- For design system packages, see Write design system guidelines for Make kits in our developer documentation.
