Before you Start
Who can use this feature
Starter, Professional, Education, Organization, and Enterprise plans
FigJam
Note: This feature is currently not available in the EU.
You can use ChatGPT to turn your ideas into editable FigJam diagrams, then review and refine them in FigJam.
For other file creation and editing workflows, you can use the Figma MCP server’s use_figma tool with a supported AI client. See Write to canvas for setup, requirements, and supported products.
Connect the Figma app to ChatGPT
If this is your first time using Figma in ChatGPT, you may be prompted to connect the Figma app directly during a prompt. You can also connect the app manually at any time.
To connect the Figma app to ChatGPT:
- Open ChatGPT.
- Open the left side panel and click your profile or username.
- Select Apps & connectors.
- Scroll until you find Figma, then select Connect.
- Follow the on-screen prompts to allow ChatGPT to access Figma.
Tip: Check out OpenAI’s help center for more details on connecting apps.
Generate Figma files in ChatGPT
ChatGPT users can create Figma files directly in their chats.
- Open a conversation in ChatGPT.
- Ask for what you want to create. For example, a prompt could be “Create a FigJam flowchart.”
- We recommend explicitly triggering the Figma app for best results. To do so, start your prompt with “Figma”. Alternatively, click the + plus icon next to your prompt and select the Figma app.
ChatGPT will generate an embedded preview of your file.
- You may be directed to login or sign up for a Figma account. You can do so directly from the embedded ChatGPT preview.
If you haven’t connected Figma to ChatGPT before, you’ll be prompted to set up the connection during prompting. ChatGPT will ask for permission to connect to Figma.
How prompting works
ChatGPT uses your prompt to decide what to generate. ChatGPT may ask brief follow-up questions to clarify your intentions, such as your goal or audience.
In FigJam, diagrams are build from your description of what you’re trying to visualize or organize. ChatGPT creates a FigJam file with shapes, connectors, and text labels to help you start mapping your ideas.
Example prompts:
- Turn this napkin drawing into a diagram in FigJam.
- Read the attached product requirements document to create a flowchart of the 2FA flow in FigJam.
- I’m prepping for a systems design interview. Can you give me an example FigJam diagram modeling a service-oriented architecture for an E2E payments application?
ChatGPT is best used to generate a structured starting point you can refine in Figma. To edit visuals, add text, or replace content, open the file in Figma after it’s generated.
Open and edit the file in Figma
Select Open in Figma (mobile) or Edit in Figma (desktop) from the chat to continue working in FigJam.
- If you’re signed in to a Figma account, you can claim the file and add it to your drafts (and select a team if you belong to more than one).
- If you’re not signed in, you can log in or create a new account to claim the file and add it to your drafts.
Files created from ChatGPT that haven’t been claimed are public and viewable by anyone with the link. Once you log in, sign up, or add the file to your drafts, it becomes private to you.
Note: You can open and view Figma files on mobile, but we recommend using desktop for editing.
Additional resources
- What is Figma: Learn about Figma’s design and collaboration products.
- Guide to FigJam: New to FigJam? Explore features for brainstorming, developing, and organizing ideas collaboratively.
- OpenAI Help Center: Find guidance on using ChatGPT.
