Who can use this feature
Available on all plans
Requires edit access to the site file
Import your existing content into the Figma Sites CMS by uploading a comma-separated values (CSV) file to create a new collection. There are two steps to this process:
1. Prepare your CSV for import
Each column in your CSV becomes a field, and each row becomes an item. Use this checklist to make sure your CSV file imports successfully:
- Export the file as CSV (UTF‑8).
- Include a single header row with no empty or duplicate column names.
- Two of these columns must be called Title and Slug.
- Make sure every value in the Slug column is unique. This could be a numeric ID like
12345or a version of the title likewelcome-post. - Images must be available in JPEG, GIF or PNG formats from publicly accessible HTTPS URLs. Make sure you link directly to the image file, not to a webpage that contains it.
- The CSV file must under 2 MB.
- There is a maximum of 200 items (rows of content). Each collection in CMS is currently limited to 200 items while in beta.
- Use the supported fields guide below to make sure your content is correctly formatted for import.
Tip: You don’t need to import every column in your CSV. Only the columns you choose to import will be created in the CMS collection.
Supported fields
Content in your CSV should match these field types:
CMS field types |
How to format the CSV column |
Example |
Title (required) |
Plain text |
Slug (required) |
Lowercase letters, numbers, and hyphens only; no spaces |
Plain text |
Plain text |
Rich text |
Plain text, HTML, or Markdown |
Link |
Full URL beginning with |
Image |
Public, direct URL to an image file; supports JPEG, PNG, and GIF formats |
Date |
Any ISO-8601 date that includes a year, month, and day; date won't be valid if it doesn't have all three |
Example data to test
Below is a mock dataset you can use to test importing.
Title |
Slug |
Artist |
ID |
Album description |
Publish date |
Sgt. Pepper's Lonely Hearts Club Band |
sgt-peppers-lonely-hearts-club-band |
The Beatles |
1001 |
<p><strong>Landmark pop album</strong> blending rock, psychedelia, and studio experimentation.</p> |
1967-06-01 |
Pet Sounds |
pet-sounds |
The Beach Boys |
1002 |
<p><em>Orchestral pop masterpiece</em> whose harmonies and production redefined studio music.</p> |
1966-05-16 |
Kind of Blue |
kind-of-blue |
Miles Davis |
1003 |
<p>Modal jazz cornerstone celebrated for <strong>spacious improvisation</strong> and tone.</p> |
1959-08-17 |
Nevermind |
nevermind |
Nirvana |
1004 |
<p><strong>Grunge breakthrough</strong> that brought alternative rock to the mainstream.</p> |
1991-09-24 |
Abbey Road |
abbey-road |
The Beatles |
1005 |
<p>Polished Beatles classic famous for its <em>side-two medley</em> and iconic cover.</p> |
1969-09-26 |
2. Import your CSV and map the fields
Follow these steps to upload your CSV, map the fields, troubleshoot issues, and create your new collection. A collection can currently have a maximum of 100 fields.
- From a Figma Sites file, click CMS in the left navigation bar.
- Click Add collection and choose Import CSV.
- Click Upload from computer and select your CSV file.
- Map columns to fields. For each column, choose a field type from the dropdown. You can rename fields as needed.
- Click Import. Your collection and items are added to the CMS.
Note: If your images aren’t showing up after import, we recommend double-checking they are mapped to an Image field rather than a Link field.
Tip: You can adjust the schema and data after importing. For example, for the Album collection, we could consider adding a cover image using a new Image field.
Troubleshooting
Quick fixes for the most common problems:
Issue |
How to fix |
Parsing or encoding errors |
Re-export as CSV (UTF-8) and remove non-printing characters or smart quotes. |
Missing header row |
Re-export the file and include a single header row. |
Wrong file type |
Upload a |
Data mismatch |
Change the field type from the column dropdown or fix the values in your CSV (e.g., non-date strings in a Date column). |
Image not appearing |
Confirm the image URL is public and references the actual image file. Replace the URL or upload the image directly to the item after import. |
Invalid URLs |
Ensure Link and Image columns contain valid, publicly accessible |
Duplicate slugs |
Slug values must be unique. Edit the CSV to de-duplicate, then try again. |
Dates import incorrectly |
Use ISO 8601 ( |
Missing Title or Slug field |
Make sure your CSV contains two columns named Title and Slug. |
