Who can use this feature
Available on any plan
Anyone with can edit access to a file can create and edit components
You can create a component out of any collection of objects or layers. Components can be as simple as shapes, buttons or fields, or more complex design like cards and menus.
Tip: Variants allow you to group and organize similar components into a single container. This simplifies your component library and makes it easier for everyone to find what they need. Learn more about creating variants.
Create a component
To create a component:
- Select the layers you’d like to be included in the component.
 - Do one of the following:
- Click Create component next to the selection's name in the right sidebar
 - Right-click on your selection and choose Create component
 - Use the keyboard shortcut:
- Mac: Option Command K
 - Windows: Ctrl Alt K
Figma will nest the layers within a special component frame. Identify components in the Layers panel using the purple Component icon. Once created, you can use the Component configuration settings to add a description and documentation link for collaborators.
Create components in bulk
You can also create components in bulk. This allows you to select multiple layers and create components out of them. Create multiple components from:
- Objects and layers in frames
 - Objects and layers in groups
 - Single layers, like a path or vector network
 - Layers in a boolean operation
Note: If you select more than one layer that isn't on one of the above configurations, Figma will create a component for each individual layer.
- Select the layers you want to create components from,
 - Click next to the selection's name in the right sidebar to open the Create component options menu.
 - Select Create multiple components from the options.
 - Figma will create a component for each frame, group, boolean operation, or path.
Delete a component
You can delete components at any time.
Deleting a main component does not remove instances of that component from your files.
- Select the component you want to delete.
 - Press Delete.
Restore a component
If you have an existing instance of a deleted component, you can use that instance to restore the component.
There are a few ways to restore a component from an instance:
From the right sidebar
- Select an existing instance of the deleted component.
- If you are in the library file that contained the main component, click Restore Component in the right sidebar
 - If you are in a file that did not contain the main component, click Go to main component in library. Then click the Restore button in the dialog window.
From the right-click menu
- Right-click on the instance in the canvas.
- If you are in the library file that contained the main component, hover over the Main component option and click Restore main component
 - If you are in a file that did not contain the main component, click Go to main component. Then click the Restore button in the dialog window
