Create color, text, effect and layout grid styles
Before you start
Who can use this feature
Supported on any team or plan.
Anyone with can edit access to a file can create and edit styles.
Anyone with can view access to a published file can use styles from that library in files where they can edit.
Styles allow you to define a set of properties of an object, that can be reused across your designs.
Create styles for:
- Paints: fill, stroke, background color
- Text: font family, size, line height, spacing
- Effects: drop shadow, inner shadow, layer blur, background blur
- Layout grids: row, column, grid
Tip! You can give Styles both a name and a description. We recommend using the name and description to communicate how Styles should be used in your designs, versus simply using a description of the color.
To make finding and selecting styles easier, you can also organize your styles into folders. Learn more about naming, managing, and sharing styles →
Colors (paints)
Color styles can be applied to fills, strokes, backgrounds and text. You can even create color styles for images or gradients.
To create a color style:
- Select the object you'd like to create a style for.
- In the properties panel, click the icon next to the property you would like to save.
- Click the icon in the Color styles panel to create a new style.
- Give the style a name and description and click Create style. Descriptions display when hovering over the style in the style picker.
Note: When creating a style for a gradient, both the colors used and the gradient direction, or angle, will be saved to the style.
Text
Styles can also be applied to text. This is great when you want to set different properties for different blocks of text.
You can apply a Text style to an entire block of text, or apply it to just some of the text within a block. This is perfect for defining the style of your headers and body text; as well as determining how to style text within a paragraph like linked text.
Note: Text alignment can't be set via a Text style. You will need to set the alignment of each text block individually.
The process for creating text styles is the same as a color style:
- Select the text you’d like to create a style for.
- In the Text section of the properties panel, click the icon.
- Click the icon in the Text styles menu.
Effects
You can also create styles for any effects, like drop shadows and blurs. This allows you to save those settings for future use.
- Select the object(s) you’d like to create a style for.
- If you haven’t already, add any effects you’d like to save to the object.
- In the Effects section of the Properties panel, click the icon.
- Click the icon in the Effect styles menu.
Shadow styles are represented in the Effects section of the right sidebar according to their direction. For example, drop shadows are displayed as above, right, below, and left. These icons can also vary between drop or inner shadows and their x, y values.
Tip! You can create styles for objects with multiple effects applied and all effects will be included in the final style. For example: If you have multiple properties applied to an object (e.g. two drop shadow effects and an inner shadow), then all of those properties will be saved to the style.
Layout grids
You can also create styles for layout grids. This is useful if you’re wanting to replicate a specific format or structure across multiple designs.
- Create (or select) a frame in the canvas.
- In the Properties panel, add a layout grid to the frame.
- Update the layout grid to match the properties you’re wanting to save to a style.
- In the Layout grid section of the Properties panel, click the icon.
- Click the icon to create a new style.
