Before you start
Who can use this feature
Anyone on any plan can create styles. To publish styles to libraries, you'll need to be on an Education, Professional, Organization, or Enterprise plan.
Anyone with can edit access to a file can create and edit styles.
Anyone with can view access to a published file can use styles from that library in files they can edit.
Styles allow you to define a set of properties or attributes and reuse them across your designs. You can create styles for colors, text, effects, and layout guides.
View styles
View styles available to you in this file from the style picker, or view styles that live in the file from the right sidebar when nothing is selected. Styles living in a file are do not include styles from other libraries that are in use.
To view styles from other published files, you can view them in the style picker for a selected property if the style's library is enabled. Learn more about enabling libraries in a file.
Right sidebar
Once you have created at least one style within a file, you can view a list of styles living in the file from the right sidebar:
- From the file, navigate to the Design panel in the right sidebar.
 - Deselect everything on the canvas:
- Click on an empty spot in the canvas
 - Press Esc to deselect your current selection
From there, view styles living in the file from the Styles section.
Style picker
View styles from the current file and styles from other libraries from the style picker.
Click the styles icon next to the relevant property in the right sidebar. Figma will open the style picker which lets you to view any styles available for that property.
The default order for styles in the style panel is:
- Alphabetically by team name
 - Alphabetically by file name
 - Individual styles are in the same order as they appear in the right sidebar
You can toggle between list and grid views.
Manage styles
To make changes to a style, you will need to edit the style definition in its original file. It's not possible to make changes to the style from another file.
Group styles
To make finding and selecting styles easier, you can organize your styles into groups. This can be done by using the / naming convention and by creating folders.
Group by folder
You can group styles by creating folders from the Design tab of the right sidebar. Folders will be reflected from the Local styles section of the right sidebar and in the style picker when you click for a given property.
To create a folder:
- Select one or more styles:
- Press Shift and click to select a range styles
 - Press ⌘ Command / Control and click to select multiple non-adjacent styles.
 - Right-click the selected style(s) and click Add new folder.
 - Name the new folder and press Return / Enter to save.
Once created, the styles in the folder will be renamed according to their new heirarchy within the styles list. For example, if we have a style Brand / Fuchsia that was moved to the Blog folder within the Brand folder, it'll be renamed to Brand / Blog / Fuchsia.
To delete a folder and the styles in it, right-click the folder name and select Delete. You can also move all styles to another location to keep the styles and delete the folder.
Group by name
Grouping styles using the slash naming convention involves adding a prefix to your style names so Figma groups them under the same heading.
In the example below, we use the slash naming convention to name and organize our styles:
Blog/colorBrand Style Guide/ColorSecondary/Color
Tip Styles appear in the styles panel in the order they appear in the Local styles list. To change the order your styles appear, you can update by clicking and dragging them in the Local styles list from the file in which they were created.
Reorder and move styles
When you view the Styles section in the right sidebar, you can see every style in the current file, grouped by the style type: text, color, effect, and layout guides.
By default, Figma will show styles in the order they were added. To make them easier to find and navigate, you can change the order or folder in which they appear.
- Press and hold Shift and click to select a range styles.
 - Press and hold ⌘ Command / Control and click to select multiple non-adjacent styles.
 - Drag the style to change the order or move them to a new folder.
Moving a style from one folder to another changes the name for the style to reflect its place in the hierarchy. For example, moving the color style Brand Style Guide / blue to the Blog folder will also change the style name to Blog / blue.
Note: You can only adjust the order for styles that live in the current file you're in, Figma sorts styles in the style picker differently.
Edit styles
You can edit styles that live in the file from the right sidebar and from the style picker.
- Right sidebar: hover over the style, then click the adjust icon when it appears.
 - Style picker: right-click on the style and select Edit style from the options.
View styles and their properties at the top of the Edit style panel.
- View or update the Name of the style.
 - Add or update the style description, which displays when hovering over the style in the style picker.
 - View or make changes to any properties of the style.
 - Click on the icon to hide or show the property on any objects the style is applied to
 - Click the icon to remove the property from the style
Any changes you make to the style here will update any objects in the file that use this style.
Tip: Access the original style when you view the style in the right sidebar. Right-click the style and select Go to style definition to open the file and edit the style there.
Copy and paste styles
You can copy existing styles from one file and paste them into another.
To copy and paste a style:
- Click an empty spot on the canvas to de-select all layers.
 - Locate the style you wish to copy under the Styles section in the right sidebar.
 - Right-click the style and select Copy style from the dropdown menu, or use the keyboard shortcut:
- Mac: ^Command C
 - Windows: Control C
 - Open the destination file where you want to paste your style.
 - Right-click the canvas and select Paste here, or use the keyboard shortcut:
- Mac: ^Command V
 - Windows: Control V
Your pasted style will appear at the bottom of the Styles list in the destination file.
Move styles between files
Warning: Before attempting to move styles between files, keep in mind that the only way to reverse the action is to repeat the entire process. It's not possible to reverse this action by using the undo keyboard shortcut or by restoring the file to a previous version.
To move styles between files:
- Open the library file where the styles currently live. This is the source file.
 - Select styles or style folders:
- Hold Shift and click to select a range of styles.
 - Hold ⌘ Command/Control and click to select multiple non-adjacent styles.
 - Right-click the selected styles > Cut styles to add them to your clipboard. You can also use the shortcut:
- Mac: ⌘ Command X
 - Windows: Control X
 - Open the file you want to move the styles to. This is the destination file.
 - Right-click on the canvas > Paste here to paste the styles into the file. You can also use the shortcut:
- Mac: ⌘ CommandV
 - Windows: CtrlV
Publish library changes
When you move published styles between files, Figma prompts you to publish your changes to any affected libraries.
You must publish these changes to complete the move process. Figma pushes updates to all subscribed files when you publish your changes.
- Click Publish in the notification window, or use the shortcut to open the library modal:
- Mac: ⌥ Option 3
 - Windows: Alt 3
 - Add a description of your changes. Figma shows this in the file’s version history.
 - Click Publish.
Figma pushes updates to any file that uses those styles. You'll see the usual bell notification and a prompt to receive updates from the library. Learn how to review and accept updates from libraries.
Reverse or undo a style move
It's not possible to undo the action of moving styles using any of these methods:
- ❌ Using the undo keyboard shortcut
 - ❌ Restoring an earlier version of either file
To reverse a style move, we recommend repeating the method outlined in the previous sections to move the style back to its original file. Be sure to publish and accept the changes afterwards.
Duplicate styles
To save time when creating styles for your design system, you can duplicate existing styles instead of creating new ones each time.
To duplicate a style:
 - Locate the style you plan to duplicate under the Styles section in the right sidebar.
 - Right-click the style and select Duplicate style from the dropdown menu.
The duplicated style will appear in the Styles list directly below your selection.
Delete styles
If you would like to remove one or more styles, you can do this directly from the panel.
 - Select Delete style from the options.
 - Figma will remove the style and you will no longer be able to use it. Any objects using that style will keep their properties, but are detached from the style.
Share styles
To access your styles in other files and projects, you can publish them to a team library. You can publish styles on their own, or alongside any components.
Note: Publishing assets—styles, components, and variables—to team libraries is available on paid plans.
Publish styles to a library
- Open the Assets panel in the left sidebar and click the  Library icon. Or, use the keyboard shortcuts:
- Mac: ⌥ Option 3
 - Windows: Alt 3
 - In the This file section, click Publish next to the file name.
 - Add a description of the changes you've made to the file. Figma will include your description in the version history of the file.
 - Click Publish to share them as a library.
When you publish changes to a library, Figma will prompt anyone using this library to receive updates. This makes sure any layers that use these styles use the most recent version.
Use styles from a library
When you enable a library for a file, anyone with can edit access to that file can access those styles and components.
- View any style from that library in the style picker.
 - View any styles from that library as a separate palette in the color picker.
 - Use any styles that are shared with you. Learn how to apply styles.
 - Edit styles from files you have
can editaccess to.
