Every Figma file has a unique URL. When you click a file link, Figma opens the file in the browser by default. Once a file is open in the browser, you can choose to open it in the Figma Desktop app instead. You can also update your preferences to always open links in the desktop app by default.
Note: The option to Open links in desktop app applies to individual Figma files, not other parts of the Figma application like the file browser or Community pages.
Tip: If Figma links aren’t opening as expected, check that your browser meets the minimum requirements for Figma.
Open the current file in the desktop app
If you have a file open in the browser, you can choose to open it in the desktop app. The desktop app requires macOS 12 or later, or Windows 10 or later in a 64-bit environment. Download and install the Figma desktop app, then log in using the same account you’re using in the browser. For government accounts, use the Figma for Government desktop app.
- Click Main menu.
- Select Open in desktop app from the dropdown.
Open links in the desktop app by default
You can update your preferences to open file links in the desktop app by default.
- In a Figma file, navigate to Main menu > Preferences.
- Select Open links in desktop app. If you don't see this option, check out tips on troubleshooting Figma links.
A checkmark appears to show the setting is enabled.
Tip: You can also enable this setting using the actions menu.
- Use the keyboard shortcut to access the actions menu:
- Mac: Command K
- Windows: Control K
- Type Open links in desktop app.
- Check the box to toggle the setting on.
Disable opening links in the Figma desktop app by default
To turn this setting off:
- Open a Figma file. If you're logged into multiple accounts in the desktop app, first select the account you want to disable this feature for.
- Select Preferences > Open links in desktop app to uncheck and disable the setting.
You can also do this using the quick actions bar.
