Keyboard shortcuts in Figma
If you're using UI3, Figma's new design, some parts of this article might not match what you see in the product today. We appreciate your patience while we make updates. Learn more about Figma’s redesign →
Who can use this feature
Available on any plan
When you're getting into a state of flow, the line between tool and designer blurs, giving you the freedom to explore the problems you're trying to solve. To save you from any unnecessary clicking and scrolling, we've put some handy keyboard shortcuts at your fingertips.
Note: It's currently not possible to create custom keyboard shortcuts. This is something to consider if you have applications with conflicting shortcuts. For example: a shortcut to open your password manager.
Keyboard shortcuts
You have access to a range of keyboard shortcuts in Figma Design and FigJam files.
View shortcuts panel
Open the keyboard shortcuts panel to view a selection of shortcuts. You can see which shortcuts you've already used, or discover new ways to speed up your workflow.
There are two ways to open the shortcuts panel:
- Click Help and resources in the bottom-right and select Keyboard shortcuts
- Use the keyboard shortcut:
- Mac:ControlShift?
- Windows:CtrlShift?
Figma will open the shortcuts panel along the bottom of your screen. Use the tabs at the top of the panel to explore shortcuts related to each set of actions. To view your current keyboard layout or select another one, select the Layout tab.
You can continue to use in Figma while viewing the keyboard shortcuts panel. Try out a new shortcut and watch the panel update.
Click to close the panel.
Shortcuts you've already used are shown in blue, shortcuts you haven’t are shown in white.
Shortcuts you've already used are shown in purple, shortcuts you haven’t are shown in white.
Note: Figma shows shortcuts based on your device. On some devices you’ll see a key’s symbol instead of the full name. Hover over the symbol to see the full expression.
