Getting Started with Imports
Before you Start
Who can use this feature
Users on Any plan can import Files
Users with Edit access can import Files to a team. Anyone can import Files to their Drafts.
Users with Edit access can import image or vector files into a File
Moving files between tools doesn't need to be painful. You can import a range of different file types into Figma.
This includes entire design files from Sketch or Figma, as well as individual Image and Vector files.
There are many different ways to import Files into Figma. The best method will depend on what type of File you are wanting to import.
I want to import:
The table below details which methods are supported for each File type.
Import images
There are many ways you can add images to Figma.
- Drag and drop images onto the Canvas
- Import files via the File Browser
- Upload an Image as a fill
- Paste images from your clipboard
- Copy and paste images between objects
- Add images to objects in bulk with place image
- Add animated GIFs to prototypes
Learn more about importing images in our Add images to your designs article.
Import vectors
Exporting and importing Vectors often requires conversion. Depending on the quality of the exporter/importer, this can often be a lossy process.
As SVG is a lossless format, we recommend exporting SVG files.
You can import vectors via a couple of different methods:
- Importing entire Sketch or Figma Files that contain vectors.
- Copying layers in other design tools and pasting them in Figma.
- Exporting vectors as SVGs and importing them into Figma.
Learn more about importing and exporting vectors in our Copy assets between design tools article.
Note: If you are working with large file sizes, especially files with multiple pages and lots of images, then you may encounter issues importing these into Figma.
Files still loading or images can't be viewed? We recommend breaking up the original file into smaller files before you try to import again.
Import entire design files
There are a couple of ways you can import entire design files into Figma. Import them using the file importer or drag and drop files into the file browser. Learn how to import files →
Missing fonts? If you're using Figma in the browser then you will need to download the Figma Font Helper to access any locally available fonts.
The Figma Desktop app will already have access to local fonts by default. Learn more about managing missing fonts in our Manage missing fonts article.
