Create interactions
Before you start
Who can use this feature
Users on any team or plan can create prototypes.
Anyone with can edit
access to a file can create prototypes.
Prototypes are interactive designs.
All prototypes start with a single interaction. Each interaction has a trigger (what causes the interaction to start) and an action (the result of the trigger).
Some interactions take place on a single object. For example:
- Clicking an object to open an external URL
- Clicking a video to play or pause it
Other interactions take place between two objects or frames. These interactions are considered connections. For example:
- Clicking a button to navigate to the next frame
- Clicking an object to open an overlay
A prototype connection consists of three parts:
- Hotspot: A hotspot is where the interaction takes place. A hotspot can be the frame itself, or an object within the frame. You can create a hotspot on anything, like a button, icon, or heading.
- Connection: A connection is the arrow or "noodle" that connects the hotspot to the destination. Define the interaction trigger, actions, and adjust animation settings from the connection.
- Destination: The destination is where a connection ends. In most cases, the destination must be a top-level frame. Only connections using the Scroll to action can be set to a destination within the same top-level frame.
Create an interaction
An interaction is created by selecting a hotspot, or starting point.
- Navigate to the Prototype tab of the right sidebar.
- Select a layer or object for the interaction's hotspot.
- Create the interaction by doing one of the following:
- Hover over the object, and drag the plus icon to the destination frame
- Click the plus icon in the Interactions section of the Prototype panel.
- Once the interaction has been made, use the Interaction details panel to set the interaction trigger, action, and destination.
Create interactions in bulk
You can create interactions from multiple objects at once. This can help you save time when creating multiple connections to the same destination.
- Select your starting objects, or hotspots, where the interactionss begin. You can select multiple objects via one of the following methods:
- Select an initial object, then hold down Shift while clicking additional objects
- Drag your cursor across any objects you want to select
- Create the interactions by doing one of the following:
- Hover over one of the selected objects, then click and drag the plus icon to the destination frame
- Click the plus icon in the Interactions section of the Prototype panel, and use the Interaction details panel to set the trigger, action, and animation details
Interaction details
Once you create an interaction, use the Interaction details modal to configure the following:
Trigger: Defines what type of interaction will cause the prototype to advance forward, such as a mouse click or touch gesture.
Learn more about Figma’s prototyping triggers → -
Action: Defines what type of event happens when a user interacts with the hotspot, such as moving to another frame, or engaging an overlay.
Learn more about Figma’s prototyping actions → - Destination: Defines where the interaction ends. This could be another screen in the prototype, or an overlay that appears above the current screen. Not all interactions have destinations—for example, the Back trigger automatically returns to the previous frame.
Animation settings: Determine how the prototype moves from one frame to the other.
Learn more about animation settings ↓ -
State management: Click to reset object properties and states when navigating in and across frames.
Learn more about prototyping state management → -
Add action: Add another action to the same trigger.
Learn more about multiple actions → - Close the Interaction details modal.
A single object can have multiple interactions, each with its own trigger. For example, you might have an object with a video fill that has two interactions: One that plays the video On click and one that opens an overlay When video ends.
A single object can have:
- Any number of the following triggers:
- Key/Gamepad
- On drag
- When video hits
- One of each of the following triggers:
- On click / On tap
- While hovering
- While pressing
- Mouse enter
- Mouse leave
- Mouse down / Touch press
- Mouse up / Touch release
- After delay
- When video ends
Note: You're not able to combine On click / On tap with While hovering. Instead, consider using Mouse enter and Mouse leave triggers in place of While hovering.
Adjust the animation
The animation settings determine how the prototype moves from one frame to the other.
Animation: The animation is how the prototype transitions from one frame to the next, such as push, slide, or dissolve.
Learn more about Figma’s animation types → - Direction: For certain animation types (such as move in or push), you can set the direction controls which way you want the transition to move in. Choose between left, right, down, or up.
Animate matching layers: Check this box to apply the Smart animate transition to any matching layers.
Learn more about Smart animate → -
Easing and spring animation: Easing determines the acceleration of the transition between a starting frame and its destination.
Learn more about Figma’s easing options → - Duration: Duration controls how long it takes, in milliseconds (ms), to complete the transition. Choose a duration between 1ms and 10000ms (10 seconds).
- Preview the animation.
Select and edit interactions
Use the tools below to improve and speed up prototype editing.
Select matching interactions
Matching interactions are identical interactions that begin from matching objects in other frames.
- Identical interactions are interactions with the same action and destination
- Matching objects are objects in different frames that have identical names and matching hierarchy levels
Tip: Figma makes it easy to identify matching objects—when you hover over an object, any matching objects in other frames are highlighted. Learn more about viewing matching layers →
To select matching interactions:
- Select an interaction.
- On the Interaction details modal, click Select matching interactions.
Edit interaction details to update all selected interactions at once.
Note: We’ve tidied up the canvas! When there are matching interactions on a canvas, only the first connection (the top-left one in view) is displayed. Select that connection to display all other matching interactions in view.
Update connection destinations in bulk
If you have multiple connections, you can change the destination of those connections at the same time.
- Select the connections you want to edit. You can select multiple connections via one of the following methods:
- Select an initial connection, then hold down Shift while clicking additional connections.
- Drag your cursor across any connections you want to select. This will create a blue box around the selected connections.
- Hold and drag the connections to a new destination frame. You can also select the interaction from the right sidebar and change the destination frame from the Interaction details panel.
Copy and paste interaction details
Prototype faster by copying interaction details and pasting them on other objects.
- Select an object or frame with an existing interaction.
- In the Interactions section, click to the left of an interaction until its line is highlighted in blue.
- Press ⌘ Command / Control + C to copy the interaction details.
- Select another frame or object.
- Press ⌘ Command / Control + V to paste the interaction details.
