Who can use this feature
Anyone with a Figma account can browse the Figma Community. You need a Community profile to follow profiles, or comment on and like files, plugins, and widgets.
Comments let you engage with other members in the Figma Community. Use comments to provide encouragement, ask for feedback on your work, and build meaningful relationships with other creators.
You can't add, edit, or reply to comments when browsing Community as a team or organization admin. Browse under your own Community profile to add or reply to comments. Manage team and organization profiles →
Add comments
There are two types of comments in the Figma Community:
- General comments on a file, prototype, plugin's listing page, or widget's listing page.
- Pinned comments left on a specific location in a Community file
Tip! Add an emoji to your comment by typing : and the emoji name. For example, type :heart_eyes:
to add a 😍 emoji.
Add general comments
To add a general comment to a file, plugin's listing, or widget's listiing:
- Click on a file, plugin, or widget in the feed to open the listings.
- If the creator has turned on comments for their resource, you'll see the option to Add a comment.
- Type your message in the field.
- Click Post to add your comment.
Note: It's not possible to reply to a specific person's general comment.
Add pinned comments
Pinned comments let you leave feedback on a specific part of a published Community file. Use the viewport to add a pinned comment directly in the creator's file.
- Open the listing page for the file.
- Click in the top-right corner of the viewport to enter comment mode.
- Your cursor will turn into a icon. Click on the location in the canvas where you'd like the comment to appear.
- Type your comment in the field, then click Post to send.
Mention creators
You can @mention other creators in general and pinned comments so they are notified.
- Begin typing your message in a general or pinned comment.
- Press @ and type a creator's name to search for their profile.
- Select a profile from the listed results.
Note: It currently isn't possible to @mention an Organization or team profile.
Manage comments
View and reply to comments
General comments
You can view general comments on the listing page of your file, plugin, or widget. It's not currently possible to reply to general comments, only pinned comments.
Pinned comments
You can use comment mode in the viewport to see other people's comments on the current file and reply to them.
To view pinned comments:
- Click in the upper-right corner of the viewport to enter comment mode.
- Use the right sidebar of the viewport to browse and filter comments.
To reply to a pinned comment:
- Click on a comment in the right sidebar when in comment mode.
Note: It's not currently possible to reply to a general comment, only a pinned comment.
Edit and delete pinned comments
To edit or delete a comment you pinned on someone's file:
- Click on the comment or thread in the right sidebar when in comment mode.
- Click in the comment you want to edit or delete.
Report comments
Anyone can report any comment considered offensive, harassment, or is in violation of the Figma Community Guidelines.
When you report a comment made on a resource you have published, Figma will immediately remove the comment. Comments you report that are made on someone else's resource will be flagged to an internal committee at Figma for review and potential removal.
To report a comment:
- Navigate to the comment you'd like to report.
- Click in the comment.
- Click Report comment from the menu.
Manage comment settings
Figma notifies you of any comments left on the listing page for one of your published resources, like files, prototypes, plugins, or widgets.
Figma also notifies you of any replies to pinned comment threads you're active on. Manage your comment notification preferences →
Allow comments on your files, plugins, or widgets
By default, comments are turned on for all files, plugins, and widgets in the Community. You can turn commenting on or off any time you publish and edit a file, plugin, or widget, including publishing updates.
From the publishing modal:
- Scroll to the Comments section at the bottom of the modal.
- Check the box next to Allow comments from Community members to turn general comments on.
- For files, click next to More options to turn on pinned comments.
Publish files to Figma Community →
Publish plugins to Figma Community →
Publish widgets to Figma Community →
Turn off comments
Comments are turned on for all resources, by default. As a creator, you can turn commenting off and on when publishing and editing a file or plugin. If you don't see an option to leave a comment, the creator of that resource has disabled them.
To turn off comments on a published resource:
- Open the listing page for your file, plugin, or widget.
- Scroll to the bottom of the listing page.
- Click Edit this page on the right.
- Click the next to More options to turn on pinned comments on your files.
Remove and restrict individual comments
You can restrict another Community member from posting future comments to your resources and files or @mentioning you in comments at any time. Restricting a user will also remove all past comments made by them from your Community files, plugins, and widgets.
To remove a comment:
- Navigate to the comment you'd like to restrict.
- Click Restrict user's comments.
To restrict a community member's profile:
- Navigate to their Community profile.
- Click under their profile info.
- Click Restrict user.
