Before you Start
Who can use this feature
Available in Figma Design and Figma Draw
Available on all paid plans
Anyone with can edit access to a file can use vectorize
Vectorize image lets you turn static images, such as hand-drawn symbols, lettering, and illustrations, into editable vector layers with Figma AI.
Note: Figma AI uses a credit system that is shared across all Figma AI features and products, including some tools mentioned in this article. Learn more about how AI credits work.
Vectorize an image
To convert a raster image into vector artwork:
- Select an image layer.
- In the secondary toolbar, click More and then select Vectorize. Depending on the complexity of the image, the vectorization process may take a few seconds.
- Once the image is converted, use the Recolor settings to refine the artwork:
- Full color: Retains the colors of the original image. Use the Number of colors setting to specify the number of colors used in the vectorized artwork.
- Grayscale: Converts the image to shades of gray. Use the Number of grays setting to specify the number of grays used in the vectorized artwork.
- Black and white: Converts the image to a two-tone vector using only black and white. Use the Threshold setting to control which parts of your artwork become black or white.
- Click the checkmark in the secondary toolbar to save your changes.
Note: Complex or low-resolution images may not vectorize well. Using Remove background or Boost resolution before vectorizing may improve your results.
